Using D1 Mini with TFT-Display and mlx90640
Hi, I am currently working on a project in which I want to work with the mlx90640 sensor and a TFT display. If I flash both separately from each other it works without problems with the respective code. But when I combine the code to run them together, I constantly get the message/error message “GetFrame Error: -1”. As far as I could find so far, it seems to be because the sensor cannot finish writing its array. However, the solutions I have found online do not work. Can anyone here perhaps help me?
If anyone needs it, here is the code:
    Thermal Camera by Hexa
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library for ST7735
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#include <Wire.h>
#include "MLX90640_API.h"
#include "MLX9064X_I2C_Driver.h"
#define TFT_RST     D0  // you can also connect this to the Arduino reset in which case, set this #define pin to -1!
#define TFT_CS      D1
#define TFT_DC      D2
#define TFT_SCL     D5
#define CAM_SCL     D6
#define SDA         D7
#define VCC         "3v3"
#define GND         "GND"
#define TA_SHIFT    8 //Default shift for MLX90640 in open air
#define THERMAL_BLACK 0x0000
#define THERMAL_BLUE 0x000F
#define THERMAL_LIGHTBLUE  0x07FF
#define THERMAL_GREEN 0x07E0
#define THERMAL_LIGHTGREEN 0xAFE5
#define THERMAL_YELLOW 0xFFE0
#define THERMAL_ORANGE  0xFD20
#define THERMAL_RED 0xF800
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS,  TFT_DC, TFT_RST);
float highest_temp = 30;
const byte MLX90640_address = 0x33; //Default 7-bit unshifted address of the MLX90640
float image[24][32];
static float mlx90640To[768];
paramsMLX90640 mlx90640;
    setup
  Wire.begin(SDA, CAM_SCL);
  Wire.setClock(400000); //Increase I2C clock speed to 400kHz
  Serial.print("Thermal Camera Device by HexaDevelopmentDE");
  uint16_t time = millis();
  if (isConnected() == false) {
    Serial.println("MLX90640 not detected at default I2C address. Please check wiring. Freezing.");
    while (1);
  Serial.println("MLX90640 online!");
  //Get device parameters - We only have to do this once
  int status;
  uint16_t eeMLX90640[832];
  status = MLX90640_DumpEE(MLX90640_address, eeMLX90640);
  if (status != 0) {
    Serial.println("Failed to load system parameters");
  status = MLX90640_ExtractParameters(eeMLX90640, &mlx90640);
  if (status != 0) {
    Serial.println("Parameter extraction failed");
  tft.initR(INITR_BLACKTAB);
  tft.setRotation(1); // rotate 90 degrees
  Serial.println("Initialized");
  time = millis() - time;
  Serial.print("Boot Time: ");
  Serial.println(time, DEC);
  tft.fillScreen(ST77XX_BLACK);
  drawtext("Thermal Camera Device by HexaDevelopmentDE", ST77XX_WHITE);
  tft.fillScreen(ST77XX_WHITE);
    loop
  createTempArray();
  printArray(image);
  delay(100);
    functions
void drawtext(char *text, uint16_t color) {
  tft.setCursor(0, 0);
  tft.setTextColor(color);
  tft.setTextWrap(true);
  tft.print(text);
void createTempArray() {
  for (byte x = 0 ; x < 2 ; x++) { //Read both subpages
    uint16_t mlx90640Frame[834];
    int status = MLX90640_GetFrameData(MLX90640_address, mlx90640Frame);
    if (status < 0) {
      Serial.print("GetFrame Error: ");
      Serial.println(status);
    float vdd = MLX90640_GetVdd(mlx90640Frame, &mlx90640);
    float Ta = MLX90640_GetTa(mlx90640Frame, &mlx90640);
    float tr = Ta - TA_SHIFT; //Reflected temperature based on the sensor ambient temperature
    float emissivity = 0.95;
    MLX90640_CalculateTo(mlx90640Frame, &mlx90640, emissivity, tr, mlx90640To);
  int i = 0;
  for (int y = 0 ; y < 24 ; y++) {
    for (int x = 0 ; x < 32 ; x++) {
      image[y][x] = mlx90640To[i];
      i++;
//Returns true if the MLX90640 is detected on the I2C bus
boolean isConnected() {
    Wire.beginTransmission((uint8_t)MLX90640_address);
    if (Wire.endTransmission() != 0) {
        return (false);    //Sensor did not ACK
    return (true);
void printArray(float a[24][32] ) {
  for ( int y = 0; y < 24; y++ ) {
    for ( int x = 0; x < 32; x++ ) {
      //Serial.print (String(a[y][x]) + "  ");
      float diff = highest_temp-a[y][x];
      //Serial.print (String(diff) + "  ");
      if(a[y][x] >= highest_temp) {
        tft.drawPixel(x, y, THERMAL_RED);
        //break;
      } else if(diff <= 0.25 && diff > 0) {
        tft.drawPixel(x, y, THERMAL_ORANGE);
        //break;
      } else if(diff <= 0.5 && diff > 0.25) {
        tft.drawPixel(x, y, THERMAL_YELLOW);
        //break;
      } else if(diff <= 0.75 && diff > 0.5) {
        tft.drawPixel(x, y, THERMAL_LIGHTGREEN);
        //break;
      } else if(diff <= 1 && diff > 0.75) {
        tft.drawPixel(x, y, THERMAL_GREEN);
        //break;
      } else if(diff <= 2 && diff > 1) {
        tft.drawPixel(x, y, THERMAL_LIGHTBLUE);
        //break;
      } else if(diff <= 5 && diff > 2) {
        tft.drawPixel(x, y, THERMAL_BLUE);
        //break;
      } else if(diff > 5) {
        tft.drawPixel(x, y, THERMAL_BLACK);
        //break;
