Just wondering where to start with my project, im a beginner in coding and arduino so any help would be greatly appreciated
Im proposing 2 possible outcomes so far for an art installation I am building:
1 - data from 2 different sensors (for now lets say light and sound levels) to then be converted into XY coordinates on my polargraph plotter that I already have built. Each coordinate it will draw a small circle.
2 - The plotter moves in a predefined pattern (up and down the page drawing straight lines
) and the data from the 2 sensors interfere with the movement to create sideways movement (so it will look a bit like a sound wave)
my polargraph is built on an arduino uno and an adafruit motor shield v1. I control it via a program built in processing - https://www.instructables.com/id/Polargraph-Drawing-Machine/ but im guessing I cannot really use this software and would probably be easier to just code it from fresh.
Presumably the Processing program sends data to the Arduino that is controlling the motors.
It seems to me you have two broad options.
A. find some automated way to send codes for the move to the Processing program. I have no idea how to do that.
B. find out what the Processing program sends to the Arduino and write a different program to send the same sort of thing to the Arduino.
My guess is that the interface between Processing and the Arduino is relatively simple and it should be possible to determine it by studying the Arduino code. You may even be able to get simple things to happen using the Arduino Serial Monitor.
I am assuming (but I don't think you have said) that your sensors will be connected to a different Arduino and not to the one that is controlling the drawing process.
...R
PS I bought some cord with the idea of making a polargraph but the project never got any farther than that
