Using data read from CANBUS
My apologies for how simple this question is, but I'm having a bit of a mental block (not uncommon!) and am going round in circles.
I have a CANBUS shield and after a bit of trial and error I am successfully using an example sketch to display the data that is received to the serial monitor with an Arduino UNO.
The sketch:
// demo: CAN-BUS Shield, receive data
#include <mcp_can.h>
#include <SPI.h>
long unsigned int rxId;
unsigned char len = 0;
unsigned char rxBuf[8];
MCP_CAN CAN0(10);                               // Set CS to pin 10
  CAN0.begin(CAN_500KBPS);                       // init can bus : baudrate = 500k
  pinMode(2, INPUT);                            // Setting pin 2 for /INT input
  Serial.println("MCP2515 Library Receive Example...");
    if(!digitalRead(2))                         // If pin 2 is low, read receive buffer
      CAN0.readMsgBuf(&len, rxBuf);              // Read data: len = data length, buf = data byte(s)
      rxId = CAN0.getCanId();                    // Get message ID
      Serial.print("ID: ");
      Serial.print(rxId, HEX);
      Serial.print("  Data: ");
      for(int i = 0; i<len; i++)                // Print each byte of the data
        if(rxBuf[i] < 0x10)                     // If data byte is less than 0x10, add a leading zero
          Serial.print("0");
        Serial.print(rxBuf[i], CAN);
        Serial.print(" ");
And the data I receive displayed in the serial monitor is:
ID: 1000 Data: 20 48 02 33 04 05 012 123
ID: 1003 Data: 55 130 123 40 16 00 02 162
ID: 1003 Data: 55 130 123 40 16 00 02 162 ...etc
The above is actually being generated from a second Arduino & CANBUS shield but would normally be coming from an Emerald engine management ECU link here. I have read from the ECU directly too and received all 4 sets of data OK, I'm just simulating it with a 2nd Arduino here to save taking the ECU off the car every time, plus I'm only really interested in some of the data from ID 1000 & ID 1003 anyway.
So my first question is, rather than printing this data in the serial monitor, how do I actually get the numbers into the sketch to use them? I'm fairly confident that once I have them, I'll be able to do calculations etc on them, I'm just stuck at what is probably a very low hurdle!
Secondly, how do I split out (or in some cases, join up) the data? For instance, the Coolant Temperature is byte 1 of ID 1003 so I just need the 130 on it's own in that case. Whereas the RPM is made up of bytes 0 & 1 of ID 1000, so I actually need to see 2048 rather than the separate 20 & 48 that it comes in as.
Searching seems to suggest that Strings & CharAt might be what I need, but I don't understand how to implement them :frowning:
Hi there,
Im stuck on the same issue. did you ever figure out the solution to this issue.
Thanks,
check this
