using dc motors instead of servo motors
hi guys,
i am making a robot that manourves away from obstacles, the robot move forwards and if anything was in the way it will stop, then rotates from left to right, but now when I want a basic code to work with it, I just found a code using servo motors but I only have dc motors, so please if it's possible,can you give me a basic code using dc motors. or you could just give me some changes of this code which using servo motors so it could work with dc motors.
thank you
#include <Servo.h>
int trigPin = 2;
int echoPin = 4;
long duration, cm, inches;
Servo servoLeft;
Servo servoRight;
int forward = 180; // full speed forward
int backward = 0; // full speed backward
  servoLeft.attach(10);
  servoRight.attach(9);
  Serial.begin (9600);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  //sets both servos to full speed in the same direction
  servoLeft.write(forward);
  servoRight.write(backward);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(4);
  duration = pulseIn(echoPin, HIGH);
  // converts the time to a distance
  cm = (duration / 2) / 29.1;
  inches = (duration / 2) / 74;
  delay(250);
  //Sets object detection distance to 4.5
  if (inches < 4.5) {
    //stops both servos
    servoLeft.write(90);
    servoRight.write(90);
    //sets both servos to full speed in opposite direction
    servoLeft.write(backward);
    servoRight.write(forward);
    //sets only the left servo to rotate so the robot turns
    delay(1500);
  }//end if statement
}//ends loop
Did your DC motors come with any example code? Do you even have an H-bridge driver for them? We're going to need part numbers and what pins you've plugged them into to even begin to write code for that.
