Hi
I am creating a piece of code that will turn on a buzzer for the duration that i want and whatever delays i want. I am using a digitalWrite function to use these buzzers. I know about all the other commands to use the buzzer e.g. tone, toneAC. However i need to be using the digitalWrite command.
Anyway, i am trying to work out the duration for my program to loop. I start off with inputting Timer On and Timer Off (in microseconds) into the serial monitor followed by the duration (in seconds).
I have worked out that i need to use this equation. loops = duration / (tOn+tOff);
as the tOn and tOff are in microseconds before i do this formula i need to divide it by 1000000 to get the inputted numbers into microseconds as the duration is counted in seconds.
This is where the problem comes in. In the Serial Monitor, it outputs "0", if anyone has a fix for this please help another out.
String msg1 = "Timer On(Microseconds): ";
String msg2 = "Timer Off(Microseconds): ";
String msg3 = "Duration(Seconds): ";
int tOn;
int tOff;
float timer1;
float timer2;
int duration;
int loops;
pinMode(buzzPin,OUTPUT);
//Code for Inputting Timer On
Serial.print(msg1);
while(Serial.available()==0)
tOn = Serial.parseInt();
timer1 = tOn / 1000000;
Serial.println(tOn);
//Code for Inputting Timer Off
Serial.print(msg2);
tOff = Serial.parseInt();
timer2 = tOff / 1000000;
Serial.println(tOff);
//Code for Inputting the Duration
Serial.print(msg3);
duration = Serial.parseInt();
Serial.println(duration);
loops = duration / (timer1+timer2);
Serial.println(loops);
