Using Designated Initializers in array
I need to clear only one line on my 16x2 lcd and from what I've seen the only option is to convert the blocks by spaces or 0x0. So I wrote a little function
clearLine(){
	const char tippexLine[LENGTH_LINE] = {[0 ...(LENGTH_LINE - 1)] = 0x0};
	/* some code */
If I compile this function, I get some errors.
expected identifier before numeric constant
expected '{' before '=' token
no match for 'operator='
I understand that it comes from the compiler version, but I'm not sure.
another option is to print spaces instead and define the return value of the function as void
void clearLine()
   lcd.setCursor (0,0);
   lcd.print(F("                "));
I thought of this option, but I would like to understand why the code does not work
i think you want
const char tippexLine[LENGTH_LINE] = {};
which initializes the entire array with 0s
you have an assignment to a what might be a constant
not sure what you think this means
No, its not the compiler version its the language. c++ does not support the designated initializers you are using. Your snippet works in 'c' but not in 'c++' (*.ino is compiled as c++)
are you describing static initialization?
struct Timer_s  {
    unsigned    msecs;
    byte        pinOn;
    byte        pinOff;
Timer_s timers [] = {
    {     0,  PIN_0,    PIN_NONE },
    {   300,  PIN_1,    PIN_0 },
    {   300,  PIN_2,    PIN_1 },
    {   300,  PIN_3,    PIN_2 },
    {   300,  PIN_NONE, PIN_3 },
    {     0,  PIN_1,    PIN_NONE },
    {  3000,  PIN_3,    PIN_1 },
    {  2000,  PIN_2,    PIN_3 },
    {  1000,  PIN_NONE, PIN_2 },
    {  3000,  PIN_NONE, PIN_NONE }
No, designated initializers are a convenient method to initialize arrays using ranges in c. Here some more information: Designated Inits (Using the GNU Compiler Collection (GCC))
BTW, in case you don't know and depending on personal preferences your example can be written more clearly in this way:
 struct Timer_s {
     unsigned msecs;
     byte pinOn;
      byte pinOff;
Timer_s timers[] = {
  {msecs: 0,   pinOn: PIN_0, pinOff: PIN_NONE},
  {msecs: 300, pinOn: PIN_1, pinOff: PIN_0},
   // etc
Just pointing out, if you actually send 0x00 (the value zeto) to an LCD display it will display a custom character, not a space.
in other cases, i need the space
// New Haven West turnout and route descriptions
#include "westIntlck.h"
// button i/o position
const PROGMEM ButIo_t butIos [] = {
    { Ba1, { 2, 7, "A1" }},
    { Ba2, { 2, 6, "A2" }},
    { Ba3, { 2, 5, "A3" }},
    { Ba4, { 2, 4, "A4" }},
    { Bb1, { 2, 3, "B1" }},
    { Bb2, { 2, 2, "B2" }},
    { Bb3, { 2, 1, "B3" }},
    { Bb4, { 2, 0, "B4" }},
    { Bc1, { 0, 7, "C1" }},
    { Bc2, { 0, 6, "C2" }},
    { Bc3, { 0, 5, "C3" }},
    { Bc4, { 0, 4, "C4" }},
    { Bc5, { 0, 3, "C5" }},
    { Bc6, { 0, 2, "C6" }},
    { Bc7, { 0, 1, "C7" }},
    { Bc8, { 0, 0, "C8" }},
    { Bx1, { 1, 7, "X1" }},
    { Bx2, { 1, 6, "X2" }},
    { Bx3, { 1, 5, "X3" }},
    { B_0, { 0, 0, ""   }},
// machine address and polarity
const PROGMEM SwMach_t x51n = { 51, N, 0, { 0, 0, "x51n" }};
const PROGMEM SwMach_t x51r = { 51, R, 1, { 0, 0, "x51r" }};
const PROGMEM SwMach_t s52n = { 52, N, 0, { 0, 1, "s52n" }};
const PROGMEM SwMach_t s52r = { 52, R, 1, { 0, 1, "s52r" }};
const PROGMEM SwMach_t x53n = { 53, N, 0, { 0, 2, "x53n" }};
const PROGMEM SwMach_t x53r = { 53, R, 1, { 0, 2, "x53r" }};
const PROGMEM SwMach_t x54n = { 54, N, 0, { 0, 3, "x54n" }};
const PROGMEM SwMach_t x54r = { 54, R, 1, { 0, 3, "x54r" }};
const PROGMEM SwMach_t x55n = { 55, N, 1, { 0, 4, "x55n" }};
const PROGMEM SwMach_t x55r = { 55, R, 0, { 0, 4, "x55r" }};
const PROGMEM SwMach_t x56n = { 56, N, 0, { 0, 5, "x56n" }};
const PROGMEM SwMach_t x56r = { 56, R, 1, { 0, 5, "x56r" }};
const PROGMEM SwMach_t x57n = { 57, N, 1, { 0, 6, "x57n" }};
const PROGMEM SwMach_t x57r = { 57, R, 0, { 0, 6, "x57r" }};
const PROGMEM SwMach_t x58n = { 58, N, 1, { 0, 7, "x58n" }};
const PROGMEM SwMach_t x58r = { 58, R, 0, { 0, 7, "x58r" }};
const PROGMEM SwMach_t x59n = { 59, N, 0, { 1, 0, "x59n" }};
const PROGMEM SwMach_t x59r = { 59, R, 1, { 1, 0, "x59r" }};
const PROGMEM SwMach_t x61n = { 61, N, 0, { 1, 1, "x61n" }};
const PROGMEM SwMach_t x61r = { 61, R, 1, { 1, 1, "x61r" }};
const PROGMEM SwMach_t s63n = { 63, N, 0, { 1, 2, "s63n" }};
const PROGMEM SwMach_t s63r = { 63, R, 1, { 1, 2, "s63r" }};
const PROGMEM SwMach_t x64n = { 64, N, 0, { 1, 3, "x64n" }};
const PROGMEM SwMach_t x64r = { 64, R, 1, { 1, 3, "x64r" }};
const PROGMEM SwMach_t x65n = { 65, N, 0, { 1, 4, "x65n" }};
const PROGMEM SwMach_t x65r = { 65, R, 1, { 1, 4, "x65r" }};
const PROGMEM SwMach_t s66n = { 66, N, 0, { 1, 5, "s66n" }};
const PROGMEM SwMach_t s66r = { 66, R, 1, { 1, 5, "s66r" }};
const PROGMEM SwMach_t x67n = { 67, N, 0, { 1, 6, "x67n" }};
const PROGMEM SwMach_t x67r = { 67, R, 1, { 1, 6, "x67r" }};
const PROGMEM SwMach_t x68n = { 68, N, 0, { 1, 7, "x68n" }};
const PROGMEM SwMach_t x68r = { 68, R, 1, { 1, 7, "x68r" }};
const PROGMEM SwMach_t s69n = { 69, N, 0, { 2, 0, "s69n" }};
const PROGMEM SwMach_t s69r = { 69, R, 1, { 2, 0, "s69r" }};
const PROGMEM SwMach_t x70n = { 70, N, 0, { 2, 1, "x70n" }};
const PROGMEM SwMach_t x70r = { 70, R, 1, { 2, 1, "x70r" }};
const PROGMEM SwMach_t x71n = { 71, N, 0, { 2, 2, "x71n" }};
const PROGMEM SwMach_t x71r = { 71, R, 1, { 2, 2, "x71r" }};
const PROGMEM SwMach_t x72n = { 72, N, 0, { 2, 3, "x72n" }};
const PROGMEM SwMach_t x72r = { 72, R, 1, { 2, 3, "x72r" }};
#if 1
const SwMach_t* smListNorm [] = {
   &x51n, &s52n, &x53n, &x54n, &x55n, &x56n, &x57n, &x58n, &x59n,
   &x61n, &s63n, &x65n, &s66n, &x67n, &x68n, &s69n,
   &x70n, &x71n, &x72n, (const SwMach_t*) 0 };
const SwMach_t* smListRev [] = {
   &x51r, &s52r, &x53r, &x54r, &x55r, &x56r, &x57r, &x58r, &x59r,
   &x61r, &s63r, &x65r, &s66r, &x67r, &x68r, &s69r,
   &x70r, &x71r, &x72r, (const SwMach_t*) 0 };
#endif
// #0_ Bx1 ___ x71 ___ ___ ___ ___ ___ ___ ___ x67 Bx2 ___
//                                     s66 x67 ___ ___ ___ ___ ___ ___ x58 ___ ___ ___ ___ ___ ___ Bc1 #9_
// #3_ Ba1 ___ ___ ___ x71 x70 ___ s66 ___ ___ ___ Bb1 x64 ___ ___ x58 ___ x56 ___ ___ ___ ___ x51 Bc2 #7_
// #1_ Ba2 ___ ___ ___ ___ ___ x70 x68 ___ ___ ___ Bb2 x65 x64 ___ ___ x56 ___ Bd1 ___ x53 x51 ___ Bc3 #5_
//        s52 ___ Bc4 #3_
// #2_ Ba3 ___ ___ ___ ___ x72 ___ ___ ___ x68 s69 Bb3 ___ ___ x65 ___ ___ x59 x53 ___ s52 ___ ___ Bc5 #1_
//                                                 s69 ___ ___ ___ x61 x59 ___ x57 ___ ___ x54 ___ Bc6 #2_
// #4_ Ba4 ___ ___ x72 ___ ___ ___ ___ ___ ___ ___ Bb4 ___ s63 x61 ___ ___ ___ ___ x57 x55 ___ x54 Bc7 #4_
//                                                 Bx3 s63                                 x55 ___ Bc8 #6_
// routes
const PROGMEM Route_t routes [] = {
    { Bx1, Bx2, { &x71n, &x67n }},
    { Bx1, Bb1, { &x71r, &x70n, &s66n }},
    { Bx1, Bb2, { &x71r, &x70r, &x68n }},
    { Bx1, Bb3, { &x71r, &x70r, &x68r, &s69n }},
    { Ba1, Bx2, { &x71n, &x70n, &s66r, &x67r }},
    { Ba1, Bb1, { &x71n, &x70n, &s66n }},
    { Ba1, Bb2, { &x71n, &x70r, &x68n }},
    { Ba1, Bb3, { &x71n, &x70r, &x68r, &s69n }},
    { Ba2, Bb2, { &x70n, &x68n }},
    { Ba2, Bb3, { &x70n, &x68r, &s69n }},
    { Ba3, Bb3, { &x72n, &x68n, &s69n }},
    { Ba4, Bb4, { &x72n }},
    { Bx1, B_N, { &x71r }},
    { Bx1, Bc1, { &x71r, &x70n, &s66r, &x67n, &x58n }},
    { Bx1, Bc2, { &x71r, &x70n, &s66n, &x64n, &x58n, &x56n, &x51n }},
    { Bx1, Bc3, { &x71r, &x70r, &x68n, &x65n, &x64n, &x56n, &x53n, &x51n }},
    { Bx1, Bc4, { &x71r, &x70r, &x68r, &s69n, &x65n, &x59n, &x53n, &s52r }},
    { Bx1, Bc5, { &x71r, &x70r, &x68r, &s69n, &x65n, &x59n, &x53n, &s52n }},
    { Bx1, Bc6, { &x71r, &x70r, &x68r, &s69r, &x61n, &x59n, &x57n, &x54n }},
    { Bx1, Bc7, { &x71r, &x70r, &x68r, &s69r, &x61n, &x59n, &x57r, &x54n }},
    { Bx1, Bc8, { &x71r, &x70r, &x68r, &s69r, &x61n, &x59n, &x57r, &x55r }},
    { Ba1, Bc1, { &x71n, &x70n, &s66r, &x67n, &x58r }},
    { Ba1, Bc2, { &x71n, &x70n, &s66n, &x64n, &x58n, &x56n, &x51n }},
    { Ba1, Bc3, { &x71n, &x70r, &x68n, &x65n, &x64n, &x56n, &x53n, &x51n }},
    { Ba1, Bc4, { &x71n, &x70r, &x68r, &s69n, &x65n, &x59n, &x53n, &s52r }},
    { Ba1, Bc5, { &x71n, &x70r, &x68r, &s69n, &x65n, &x59n, &x53n, &s52n }},
    { Ba1, Bc6, { &x71n, &x70r, &x68r, &s69r, &x61n, &x59n, &x57n, &x54n }},
    { Ba1, Bc7, { &x71n, &x70r, &x68r, &s69r, &x61n, &x59n, &x57r, &x54n }},
    { Ba1, Bc8, { &x71n, &x70r, &x68r, &s69r, &x61n, &x59n, &x57r, &x55r }},
    { Ba2, Bc2, { &x70n,               &x64n, &x56r, &x53n, &x51n }},
    { Ba2, Bc3, { &x70n, &x68n, &x65n, &x64n, &x56n, &x53n, &x51n }},
    { Ba2, Bc4, { &x70n, &x68r, &s69n, &x65n, &x59n, &x53n, &s52r }},
    { Ba2, Bc5, { &x70n, &x68r, &s69n, &x65n, &x59n, &x53n, &s52n }},
    { Ba2, Bc6, { &x70n, &x68r, &s69r, &x61n, &x59n, &x57n, &x54n }},
    { Ba2, Bc7, { &x70n, &x68r, &s69r, &x61n, &x59n, &x57r, &x55n, &x54n }},
    { Ba2, Bc8, { &x70n, &x68r, &s69r, &x61n, &x59n, &x57r, &x55r }},
    { Ba3, Bc2, { &x72n, &x68n, &s69n, &x65n, &x59n, &x53r, &x51r }},
    { Ba3, Bc3, { &x72n, &x68n, &s69n, &x65n, &x59n, &x53r, &x51n }},
    { Ba3, Bc4, { &x72n, &x68n, &s69n, &x65n, &x59n, &x53n, &s52r }},
    { Ba3, Bc5, { &x72n, &x68n, &s69n, &x65n, &x59n, &x53n, &s52n }},
    { Ba3, Bc6, { &x72n, &x68n, &s69r, &x61n, &x57n, &x54n }},
    { Ba3, Bc7, { &x72n, &x68n, &s69r, &x61n, &x57r, &x55n }},
    { Ba3, Bc8, { &x72n, &x68n, &s69r, &x61n, &x59n, &x57r, &x55r }},
    { Ba4, Bc2, { &x72r, &x68n, &s69n, &x65n, &x59n, &x53r, &x51r }},
    { Ba4, Bc3, { &x72r, &x68n, &s69n, &x65n, &x59n, &x53r, &x51n }},
    { Ba4, Bc4, { &x72r, &x68n, &s69n, &x65n, &x59n, &x53n, &s52r }},
    { Ba4, Bc5, { &x72r, &x68n, &s69n, &x65n, &x59n, &x53n, &s52n }},
    { Ba4, Bc6, { &x72r, &x68n, &s69r, &x61n, &x57n, &x54n }},
    { Ba4, Bc7, { &x72n, &x68n, &s69r, &x61n, &x57n, &x55n }},
    { Ba4, Bc8, { &x72n, &x68n, &s69r, &x61n, &x57n, &x55r }},
    { Bx3, Bc2, { &s63n, &x61n, &x59r, &x53r, &x51r }},
    { Bx3, Bc3, { &s63n, &x61n, &x59r, &x53r, &x51n }},
    { Bx3, Bc4, { &s63n, &x61n, &x59r, &x53n, &s52r }},
    { Bx3, Bc5, { &s63n, &x61n, &x59r, &x53n, &s52n }},
    { Bx3, Bc6, { &s63n, &x61r, &x59n, &x57n, &x54n }},
    { Bx3, Bc7, { &s63r, &x57n, &x55n }},
    { Bx3, Bc8, { &s63r, &x57n, &x55r }},
int routesSize = sizeof(routes);
