Using Diecimila as AVR ISP for a ATmega8
Dear all,
thanks a lot for all your posts concerning the usage of the Diecimila as AVR ISP together with avrdude.
First of all, I did not need to insert the 120 Ohm resistor between +5V and Reset on the Diecimila to get avrdude work fine.
Attempting to get the ATmega8 programmed from within Arduino0022 did not work due to signature problem. Overcome using avrdude with option -F.
But attempting to download a bootloader to a ATmega8 running on a 16MHz Xtal breadboard and connected as indicated in the ArduinoISP page, I got avrdude apparently successfully doing what it was supposed to, but then using the fresh programmed ATmega8 in the Diecimila board, the system does not see it (stk500 error).
Here the output of the programming sequence:
Microsoft Windows XP Version 5.1.2600 Copyright 1985-2001 Microsoft Corp.
H:>d:
D:>d:
D:>cd arduino/avr
D:\Arduino\AVR>avrdude -b 19200 -P com4 -p m8 -c avrisp
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.13s
avrdude: Device signature = 0x1e9307
avrdude: safemode: Fuses OK
avrdude done. Thank you.
D:\Arduino\AVR>avrdude -b 19200 -P com4 -p m8 -c avrisp -F
Reading | ################################################## | 100% 0.14s
D:\Arduino\AVR>avrdude -b 19200 -P com4 -p m8 -c avrisp -F -U flash:w:ATmegaBOOT.hex
avrdude: Device signature = 0x1e9307 avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option. avrdude: erasing chip avrdude: reading input file "ATmegaBOOT.hex" avrdude: input file ATmegaBOOT.hex auto detected as Intel Hex avrdude: writing flash (8170 bytes):
Writing | ################################################## | 100% 2.03s
avrdude: 8170 bytes of flash written avrdude: verifying flash memory against ATmegaBOOT.hex: avrdude: load data flash data from input file ATmegaBOOT.hex: avrdude: input file ATmegaBOOT.hex auto detected as Intel Hex avrdude: input file ATmegaBOOT.hex contains 8170 bytes avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 14.50s
avrdude: verifying ... avrdude: 8170 bytes of flash verified
Reading | ################################################## | 100% 0.11s
D:\Arduino\AVR>
I am convinced I missed a step in the command line. Wrong usage of the -U option?
The bootloader I took is the one provided within Arduino0022: D:\Arduino\hardware\arduino\bootloaders\atmega8\ATmegaBOOT.hex
Does anyone have 5 minutes to help me out?
Thanks Phil
The device signature looks fine for the ATmega8. I suspect you got the signature error when using Arduino0022 because you had not disabled auto-reset. You might want to disable the auto-reset on the Diecimila and try to burn the bootloader again using Arduino0022.
Well, thanks for the reply. In the meanwhile I have found another post describing some start-up very long delay (10s) and recommending to download a new bootloader with a start-up delay of 2s. I have not yet tried out but will do it tonight.
Did I understand you correctly, that disabling the auto-reset (meaning pulling-up RESET to 5V thru a 120R) may get Arduino0022 work fine to re-program the flash of the ATmega8 using the Diecimila (ATmega168) as AVR ISP? Or should I use avrdude as I did before?
prmd: Did I understand you correctly, that disabling the auto-reset (meaning pulling-up RESET to 5V thru a 120R) may get Arduino0022 work fine to re-program the flash of the ATmega8 using the Diecimila (ATmega168) as AVR ISP?
Yes, you understood correctly.
Good morning!
Finally I got some time to try again.
I have used avrdude as described above to download the bootLoader with 2 seconds delay.
D:\Arduino\AVR>avrdude -b 19200 -P com4 -p m8 -c avrisp -F -U flash:w:ATmega8BOOT2s.hex
avrdude: reading input file "ATmega8BOOT2s.hex"
avrdude: input file ATmega8BOOT2s.hex auto detected as Intel Hex
avrdude: writing flash (8184 bytes):
Writing | ################################################## | 100% 2.05s
avrdude: 8184 bytes of flash written
avrdude: verifying flash memory against ATmega8BOOT2s.hex:
avrdude: load data flash data from input file ATmega8BOOT2s.hex:
avrdude: input file ATmega8BOOT2s.hex contains 8184 bytes
avrdude: 8184 bytes of flash verified
The programming went apparently fine but then when trying to download a sketch I got the following error:
Binary sketch size: 5842 bytes (of a 7168 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
I used the same COM channel. So, now I feel quite confused.... Any hint?
prmd: The programming went apparently fine but then when trying to download a sketch I got the following error:
My first two guesses would be: 1) Wrong baud rate for the bootloader. 2) Auto-reset is not working.
Dear ‘johnwasser’,
again thanks for your reply.
However it did not help ;(
  1. I would not know where to change the speed in the bootloader. I used the one in the Arduino0022 distribution for ATmega8
    and also the one (only binary file available) which was supposed not to wait so long.
  2. I have tried pulling up RESET* to +5V via a 120R as suggested on my Arduino Diecimila. Its I/O Pin 10 is connected to the RESET* of the ATmega8. And the 3 ISP lines 11, 12 & 13 are connected one to one as indicated.
I do now believe the problem is apparently related to some internal settings of the bootloader:
#include <inttypes.h>
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <avr/eeprom.h>
#include <avr/interrupt.h>
#include <avr/delay.h>
//#define F_CPU			16000000
/* We, Malmoitians, like slow interaction
 * therefore the slow baud rate ;-)
//#define BAUD_RATE		9600
/* 6.000.000 is more or less 8 seconds at the
 * speed configured here
//#define MAX_TIME_COUNT	6000000
#define MAX_TIME_COUNT (F_CPU>>1)
///#define MAX_TIME_COUNT_MORATORY	1600000
The BAUD_RATE is passed to the compiler via the atmega8/Makefile
DEFS       = -DF_CPU=16000000 -DBAUD_RATE=19200
Any hints?
Hi again,
In another post 'johnwasser' wrote:
On the Arduino where you are running ArduinoISP you have to disable the auto-reset.  Find a small electrolytic capacitor (roughly 1 or 2 microfarad) and connect it between the Reset pin and Ground (+ side to Reset, - side to Ground).  You can probably harvest one off an old circuit board if you don't have a source handy.
Would it make it? The information is quite confuse, some speak of a 120 Ohm resistor ... I really believe the Arduino AVR-ISP page should be updated at some point so as to provide a proven procedure. I shall try to summarize my experience in a page ... that could be my contribution to the forum!
Now going through the forum, I also have seen the possibility to directly burn the application, if no bootloader is required. In my case, that would be the solution. I will try it out as soon I get my code compiled and linked under WinAVR into a .hex file.
Have a nice & sunny day!
Good morning from sunny Germany!
as announced I succeeded to generate the hex file for the ATmega8 and flashed it onto the chip.
BUT, while the ``` setup() ``` starts to be executed, it seems to hang in a [b]delay(5000)[/b] call.
I have crossed checked my application running it on my Diecimila with ATmega168 and it works.
Do you know of any restriction for the ATmega8 wrt ATmega168? The LCD works fine (at least I have my welcome banner properly displayed).
For the flash programming, I did not use the capacitor nor the resistor between Reset* and GND.
D:\Arduino\AVR>avrdude -b 19200 -P com4 -p m8 -c avrisp -F -U flash:w:wwcc.hex
avrdude: reading input file "wwcc.hex"
avrdude: input file wwcc.hex auto detected as Intel Hex
avrdude: writing flash (6274 bytes):
Writing | ################################################## | 100% 12.64s
avrdude: 6274 bytes of flash written
avrdude: verifying flash memory against wwcc.hex:
avrdude: load data flash data from input file wwcc.hex:
avrdude: input file wwcc.hex contains 6274 bytes
Reading | ################################################## | 100% 11.19s
avrdude: 6274 bytes of flash verified
PS: It's been quite a struggle to get the Makefile correct so as to generate a decent hex file what size is concerned. The linker was reporting the size would not fit onto a ATmega8 while the compilation/linking using the Arduino IDE was fine. I had to do with some flags:
CFLAGS += -fshort-enums -ffunction-sections -fdata-sections -ffreestanding
CFLAGS += -Wall -Wl,--relax -Wl,--gc-sections
and
CPPFLAGS += -fno-exceptions -ffunction-sections -fdata-sections -ffreestanding
CPPFLAGS += -Wall -Wl,--relax -Wl,--gc-sections
PPS: For the ATmega8 there is a warning concerning the redefinition of the macro ``` PE ``` which is defined first in iom8.h (PE = 2) and later in pins_arduino.h (PE = 5).
Any hint would be most appreciated ...! ;) Phil
