Using "DL1" (Onboard 'RGB')
Trying to get the onboard 'RGB' to blink, but failing.
With the following, Compilation fails (it doesn't like D14 / D15 to be used) --
int gLED = D15;
int rLED = D14;
  pinMode(rLED, OUTPUT);
  pinMode(gLED, OUTPUT);
  digitalWrite(rLED, HIGH);
  digitalWrite(gLED, HIGH);
  // low on, high off
  digitalWrite(gLED, LOW);
  digitalWrite(rLED, LOW);
The following, using the GPIO numbers, Compiles, but doesn't result blinking --
int gLED = 0;
int rLED = 46;
  // low on, high off
The error log (verbose) from the compilation failure (it's a doozy):
Arduino: 1.8.19 (Windows 10), TD: 1.57-beta1, Board: "Arduino Nano ES
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jacob\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jacob\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\sketchbook\libraries -fqbn=arduino:esp32:nano_nora -vid-pid=2341_0070 -ide-version=10819 -build-path C:\Users\jacob\AppData\Local\Temp\arduino_build_609215 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.openocd-esp32.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.dfu-util.path=C:\Users\jacob\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\jacob\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.mklittlefs.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -verbose C:\Users\jacob\AppData\Local\Temp\arduino_modified_sketch_207563\sketch_aug05a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\jacob\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\jacob\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\sketchbook\libraries -fqbn=arduino:esp32:nano_nora -vid-pid=2341_0070 -ide-version=10819 -build-path C:\Users\jacob\AppData\Local\Temp\arduino_build_609215 -warnings=all -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.openocd-esp32.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.openocd-esp32-v0.11.0-esp32-20221026.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\openocd-esp32\v0.11.0-esp32-20221026 -prefs=runtime.tools.dfu-util.path=C:\Users\jacob\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.dfu-util-0.11.0-arduino5.path=C:\Users\jacob\AppData\Local\Arduino15\packages\arduino\tools\dfu-util\0.11.0-arduino5 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s2-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s2-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.riscv32-esp-elf-gdb.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.riscv32-esp-elf-gdb-11.2_20220823.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\riscv32-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.xtensa-esp-elf-gdb-11.2_20220823.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp-elf-gdb\11.2_20220823 -prefs=runtime.tools.mklittlefs.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.mklittlefs-3.0.0-gnu12-dc7f933.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\mklittlefs\3.0.0-gnu12-dc7f933 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.esptool_py.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.esptool_py-4.5.1.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\4.5.1 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -prefs=runtime.tools.xtensa-esp32s3-elf-gcc-esp-2021r2-patch5-8.4.0.path=C:\Users\jacob\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32s3-elf-gcc\esp-2021r2-patch5-8.4.0 -verbose C:\Users\jacob\AppData\Local\Temp\arduino_modified_sketch_207563\sketch_aug05a.ino
Using board 'nano_nora' from platform in folder: C:\Users\jacob\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.11
Using core 'esp32' from platform in folder: C:\Users\jacob\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.11
cmd /c if exist "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_modified_sketch_207563\\partitions.csv" COPY /y "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_modified_sketch_207563\\partitions.csv" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\partitions.csv"
cmd /c if not exist "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\partitions.csv" if exist "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora\\partitions.csv" COPY "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora\\partitions.csv" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\partitions.csv"
cmd /c if not exist "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\partitions.csv" COPY "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\tools\\partitions\\app3M_fat9M_fact512k_16MB.csv" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\partitions.csv"
cmd /c IF EXIST "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_modified_sketch_207563\\bootloader.bin" ( COPY /y "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_modified_sketch_207563\\bootloader.bin" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch_aug05a.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora\\bootloader.bin" ( COPY "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora\\bootloader.bin" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch_aug05a.ino.bootloader.bin" ) ELSE ( "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\4.5.1/esptool.exe" --chip esp32s3 elf2image --flash_mode dio --flash_freq 80m --flash_size 16MB -o "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch_aug05a.ino.bootloader.bin" "C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\tools\\sdk\\esp32s3\\bin\\bootloader_qio_80m.elf" ) )
esptool.py v4.5.1
Creating esp32s3 image...
Merged 1 ELF section
Successfully created esp32s3 image.
cmd /c if exist "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_modified_sketch_207563\\build_opt.h" COPY /y "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_modified_sketch_207563\\build_opt.h" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\build_opt.h"
cmd /c if not exist "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\build_opt.h" type nul > "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\build_opt.h"
cmd /c type nul > "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/file_opts"
Detecting libraries used...
"C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32s3-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32s3-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/newlib/platform_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/port/xtensa/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/esp_additions" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include/soc" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include/soc/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3/private_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/heap/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/log/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/include/apps" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/include/apps/sntp" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/lwip/src/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/port/esp32/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/platform_port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/include/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/port/soc" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/port/public_compat" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/xtensa/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/xtensa/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/driver/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/driver/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_pm/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_ringbuf/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/efuse/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/efuse/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/vfs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_wifi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_event/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_netif/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_eth/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/tcpip_adapter/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_phy/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_phy/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_ipc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/app_trace/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_timer/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/mbedtls/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/app_update/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/spi_flash/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bootloader_support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nvs_flash/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/pthread/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/xtensa" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espcoredump/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espcoredump/include/port/xtensa" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ieee802154/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/console" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/asio/asio/asio/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/asio/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/osi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/include/esp32c3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/api/include/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/cbor/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/unity/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/unity/unity/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/cmock/CMock/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/coap/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/coap/libcoap/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nghttp/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-tls" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_adc_cal/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hid/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/tcp_transport/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_http_client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_http_server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_https_ota/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_https_server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_lcd/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_lcd/interface" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protobuf-c/protobuf-c" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/common" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/security" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/transports" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mdns/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_local_ctrl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/sdmmc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_serial_slave_link/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_websocket_client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/expat/expat/expat/lib" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/expat/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wear_levelling/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/diskio" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/vfs" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/idf_test/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/idf_test/include/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/jsmn/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json/cJSON" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/libsodium/port_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/openssl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/perfmon/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/spiffs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/usb/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ulp/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wifi_provisioning/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/rmaker_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_diagnostics/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/rtc_store/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_insights/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_parser/upstream/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_parser/upstream" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_generator/upstream" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_schedule/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rainmaker/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/gpio_button/button/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/qrcode/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ws2812_led" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/freertos" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/arduino_tinyusb/tinyusb/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/arduino_tinyusb/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_littlefs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/tool" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/typedef" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/image" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/math" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/nn" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/layer" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/detect" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/model_zoo" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp32-camera/driver/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp32-camera/conversions/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fb_gfx/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/qio_opi/include" -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NANO_ESP32\"" "-DARDUINO_VARIANT=\"arduino_nano_nora\"" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 "@C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/build_opt.h" "@C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/file_opts" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\cores\\esp32" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch\\sketch_aug05a.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32s3-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32s3-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/newlib/platform_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/port/xtensa/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/esp_additions" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include/soc" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include/soc/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3/private_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/heap/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/log/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/include/apps" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/include/apps/sntp" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/lwip/src/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/port/esp32/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/platform_port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/include/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/port/soc" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/port/public_compat" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/xtensa/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/xtensa/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/driver/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/driver/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_pm/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_ringbuf/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/efuse/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/efuse/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/vfs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_wifi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_event/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_netif/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_eth/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/tcpip_adapter/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_phy/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_phy/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_ipc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/app_trace/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_timer/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/mbedtls/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/app_update/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/spi_flash/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bootloader_support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nvs_flash/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/pthread/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/xtensa" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espcoredump/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espcoredump/include/port/xtensa" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ieee802154/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/console" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/asio/asio/asio/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/asio/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/osi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/include/esp32c3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/api/include/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/cbor/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/unity/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/unity/unity/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/cmock/CMock/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/coap/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/coap/libcoap/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nghttp/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-tls" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_adc_cal/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hid/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/tcp_transport/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_http_client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_http_server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_https_ota/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_https_server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_lcd/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_lcd/interface" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protobuf-c/protobuf-c" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/common" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/security" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/transports" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mdns/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_local_ctrl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/sdmmc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_serial_slave_link/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_websocket_client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/expat/expat/expat/lib" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/expat/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wear_levelling/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/diskio" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/vfs" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/idf_test/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/idf_test/include/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/jsmn/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json/cJSON" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/libsodium/port_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/openssl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/perfmon/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/spiffs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/usb/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ulp/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wifi_provisioning/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/rmaker_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_diagnostics/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/rtc_store/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_insights/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_parser/upstream/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_parser/upstream" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_generator/upstream" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_schedule/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rainmaker/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/gpio_button/button/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/qrcode/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ws2812_led" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/freertos" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/arduino_tinyusb/tinyusb/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/arduino_tinyusb/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_littlefs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/tool" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/typedef" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/image" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/math" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/nn" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/layer" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/detect" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/model_zoo" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp32-camera/driver/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp32-camera/conversions/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fb_gfx/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/qio_opi/include" -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -c -w -Os -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NANO_ESP32\"" "-DARDUINO_VARIANT=\"arduino_nano_nora\"" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 "@C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/build_opt.h" "@C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/file_opts" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\cores\\esp32" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch\\sketch_aug05a.ino.cpp" -o "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32s3-elf-gcc\\esp-2021r2-patch5-8.4.0/bin/xtensa-esp32s3-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.5\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/newlib/platform_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/port/xtensa/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/esp_additions" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include/soc" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/include/soc/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3/private_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/heap/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/log/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/include/apps" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/include/apps/sntp" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/lwip/src/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/port/esp32/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/soc/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/hal/platform_port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/include/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rom/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/port/soc" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_system/port/public_compat" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/xtensa/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/xtensa/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/driver/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/driver/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_pm/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_ringbuf/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/efuse/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/efuse/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/vfs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_wifi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_event/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_netif/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_eth/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/tcpip_adapter/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_phy/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_phy/esp32s3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_ipc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/app_trace/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_timer/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/mbedtls/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/app_update/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/spi_flash/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bootloader_support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nvs_flash/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/pthread/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/xtensa" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_gdbstub/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espcoredump/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espcoredump/include/port/xtensa" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ieee802154/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/console" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/asio/asio/asio/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/asio/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/osi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/include/esp32c3/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/api/include/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/cbor/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/unity/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/unity/unity/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/cmock/CMock/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/coap/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/coap/libcoap/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nghttp/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-tls" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_adc_cal/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_hid/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/tcp_transport/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_http_client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_http_server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_https_ota/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_https_server/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_lcd/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_lcd/interface" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protobuf-c/protobuf-c" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/common" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/security" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/protocomm/include/transports" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mdns/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_local_ctrl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/sdmmc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_serial_slave_link/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_websocket_client/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/expat/expat/expat/lib" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/expat/port/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wear_levelling/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/diskio" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/vfs" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fatfs/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freemodbus/freemodbus/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/idf_test/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/idf_test/include/esp32s3" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/jsmn/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json/cJSON" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/libsodium/port_include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/openssl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/perfmon/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/spiffs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/usb/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ulp/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/wifi_provisioning/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/rmaker_common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_diagnostics/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/rtc_store/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_insights/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_parser/upstream/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_parser/upstream" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/json_generator/upstream" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_schedule/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp_secure_cert_mgr/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_rainmaker/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/gpio_button/button/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/qrcode/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/ws2812_led" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/freertos/include/freertos" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/arduino_tinyusb/tinyusb/src" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/arduino_tinyusb/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp_littlefs/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/tool" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/typedef" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/image" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/math" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/nn" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/layer" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/detect" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp-dl/include/model_zoo" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp32-camera/driver/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/esp32-camera/conversions/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/dotprod/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/support/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/support/mem/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/hann/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/iir/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/fir/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/add/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/sub/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/mul/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/addc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/mulc/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/matrix/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/fft/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/dct/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/conv/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/common/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/espressif__esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/include/fb_gfx/include" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11/tools/sdk/esp32s3/qio_opi/include" -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -Wall -Werror=all -Wextra -Os -DF_CPU=240000000L -DARDUINO=10819 -DARDUINO_NANO_ESP32 -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"NANO_ESP32\"" "-DARDUINO_VARIANT=\"arduino_nano_nora\"" -DARDUINO_PARTITION_app3M_fat9M_fact512k_16MB -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PIN_REMAP -DBOARD_HAS_PSRAM "-DUSB_MANUFACTURER=\"Arduino\"" "-DUSB_PRODUCT=\"Nano ESP32\"" -DARDUINO_USB_MODE=0 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=1 "@C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/build_opt.h" "@C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215/file_opts" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\cores\\esp32" "-IC:\\Users\\jacob\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\esp32\\2.0.11\\variants\\arduino_nano_nora" "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch\\sketch_aug05a.ino.cpp" -o "C:\\Users\\jacob\\AppData\\Local\\Temp\\arduino_build_609215\\sketch\\sketch_aug05a.ino.cpp.o"
sketch_aug05a:2:12: error: 'D15' was not declared in this scope
 int gLED = D15;
C:\Users\jacob\AppData\Local\Temp\arduino_modified_sketch_207563\sketch_aug05a.ino:2:12: note: suggested alternative: 'D13'
 int gLED = D15;
            D13
sketch_aug05a:3:12: error: 'D14' was not declared in this scope
 int rLED = D14;
C:\Users\jacob\AppData\Local\Temp\arduino_modified_sketch_207563\sketch_aug05a.ino:3:12: note: suggested alternative: 'D13'
 int rLED = D14;
            D13
exit status 1
I'm not sure if this helps, but I am able to access the built in RBG LED with the following
  // turn on the blue LED.
  digitalWrite(LED_RED, HIGH); //red
  digitalWrite(LED_GREEN, HIGH); //green
  digitalWrite(LED_BLUE, LOW); //blue
// the loop function runs over and over again forever
@pindari
That works. Where's that documented (LED_RED, _GREEN, _BLUE)?
  digitalWrite(LED_GREEN, LOW);
  digitalWrite(LED_RED, LOW);
As with other official Arduino boards, you should use integer literals for Arduino pin numbers. This is a difference in Nano ESP32 compared to other ESP32 boards, where the integer literals are GPIO numbers and the Dn macros are the mapped pin numbers.
Here:
https://docs.arduino.cc/tutorials/nano-esp32/cheat-sheet#rgb
OK, this works --
int rr = 14;
int gg = 15;
  pinMode(rr, OUTPUT);
  pinMode(gg, OUTPUT);
  digitalWrite(rr, HIGH);
  digitalWrite(gg, HIGH);
  digitalWrite(rr, LOW);
  digitalWrite(gg, LOW);
(Yes, the ESP32 likes the GPIO numbers and the ESP8266, depending on the board selected uses numbers with D-prefix or GPIO numbers.)
I’ve found it works if I analogWrite (instead of digitalWrite) to the three extra PIN numbers.
