These Shields have Touch Panels that share pins with the TFT controller.
You were lucky. The TFT controller would have crashed. Most people get a white screen if you do not reset pinMode() for YP, XM after each access of the TouchScreen.
Serial.begin(9600); //.kbv for Debug
myGLCD.InitLCD();
myGLCD.clrScr();
void theTouchReads(){
TSPoint p = ts.getPoint();
pinMode(XM, OUTPUT); // .kbv Touch Pins are shared with TFT
pinMode(YP, OUTPUT); // .kbv so you must restore to OUTPUT
// .kbv for Debug, watch your Touch points
Serial.println("p.x=" + String(p.x) + " p.y=" + String(p.y) + " ");
// Si la presion esta en el rango
if (p.z > 100 && p.z < 1000) {
// pointx = map(p.x, TS_MINX, TS_MAXX, 320, 0);
// pointy = map(p.y, TS_MINY, TS_MAXY, 0, 240);
// .kbv map Touch values to screen coordinates
pointx = map(p.x, TS_MINX, TS_MAXX, 0, 320);
I still reckon it is crazy to use UTFT methods when the Adafruit methods are easier:
#include <Adafruit_GFX.h>
#include <MCUFRIEND_kbv.h>
#include <TouchScreen.h>
#define YP A1
#define YM 7
#define XM A2
#define XP 6
// .kbv my Touch screen has these values in Landscape
#define TS_MINX 140 //LEFT
#define TS_MAXX 900 //RIGHT
#define TS_MINY 940 //120 //TOP
#define TS_MAXY 120 //940 //BOT
MCUFRIEND_kbv tft;
int widh, heigh;
// Touch Screen
TouchScreen ts(XP, YP, XM, YM, 300);
int pointx, pointy;
#define ORANGE 0xF900 //weird (255, 35, 1) colour
#define WHITE 0xFFFF
#define BLACK 0x0000
tft.begin(tft.readID());
tft.setRotation(1); //Landscape
tft.fillScreen(BLACK);
showButton();
void showButton() {
tft.fillRect(100, 100, 100, 100, ORANGE); // Fill the red Rect
tft.setTextColor(WHITE);
tft.setCursor(110, 110);
tft.print("BUTTON");
while (true) {
readButton();
void readButton () {
// Read the point
theTouchReads();
// Ask if point of read is to the button
if ((pointx >= 100 && pointx <= 200) && (pointy >= 100 && pointy <= 200)) {
tft.drawRect(100, 100, 100, 100, WHITE); // Draw a white rect, no fill
delay(2000);
tft.drawRect(100, 100, 100, 100, ORANGE); // "Delete" the white rect
pointx = pointy = 0;
void theTouchReads() {
Here is a simple example that uses multiple buttons with the Adafruit_GFX_Button class:
#include <TouchScreen.h> //.kbv ? missing isTouching() method
//Y-plus, Y-minus, X-plus, X-minus
#define YP A2 //A3 //A2 //A3 // A1
#define XM A1 //A2 //A1 //A2 // A2
#define YM 6 //9 //6 //9 // 7
#define XP 7 //8 //7 //8 // 6
// teee kbv teee default Touch wiring
#define TS_LEFT 900 //200 //920
#define TS_RT 139 //920 //200
#define TS_TOP 944 //120 //940
#define TS_BOT 140 //940 //120
//Color definitions
#define NAVY 0x000F
#define DARKGREEN 0x03E0
#define DARKCYAN 0x03EF
#define MAROON 0x7800
#define PURPLE 0x780F
#define OLIVE 0x7BE0
#define LIGHTGREY 0xC618
#define DARKGREY 0x7BEF
#define BLUE 0x001F
#define GREEN 0x07E0
#define CYAN 0x07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define ORANGE 0xFD20
#define GREENYELLOW 0xAFE5
#define PINK 0xF81F
MCUFRIEND_kbv tft;
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
Adafruit_GFX_Button btns[12];
char legends[12] = "123456789*0#";
int Xposn, Yposn, tftpos, tftwid, tftht; //.kbv use intuitive names for globals
int x, y, i;
char msg[2] = "X"; //initialises msg[1] = 0 (NUL)
tft.begin(tft.readID()); //use the correct controller
tft.setRotation(0); //Portrait
tftwid = tft.width();
tftht = tft.height();
// note that Button x,y is the CENTRE and not the TLHC.
for (y = 0, i = 0; y < 4; y++) {
for (x = 0; x < 3; x++) {
msg[0] = legends[i];
btns[i].initButton(&tft, 56 + x * 64, 90 + y * 64, 60, 60,
WHITE, CYAN, BLACK, msg, 4);
btns[i++].drawButton(false);
bool getPress()
TSPoint p = ts.getPoint(); //point on touchscreen that has been touched
pinMode(YP, OUTPUT); //.kbv these pins are shared with TFT
pinMode(XM, OUTPUT); //.kbv these pins are shared with TFT
if (p.z > 10 && p.z < 1000) {
//map TSPoint to 240 X 320 pixels
Xposn = map(p.x, TS_LEFT, TS_RT, 0, tftwid); //.kbv makes sense to me
Yposn = map(p.y, TS_TOP, TS_BOT, 0, tftht);
return true;
return false;
static int old = 0;
Adafruit_GFX_Button *b; //pointer to the real button
if (getPress()) {
for (int i = 0 ; i < 12; i++) { //check all buttons
b = &btns[i];
b->press(b->contains(Xposn, Yposn));
b->drawButton(b->isPressed()); //update current state
if (b->justPressed()) {
if (tftpos >= tftwid - 12) { //last printable posn
tft.fillRect(0, 0, tftwid, 16, BLACK); //erase
tftpos = 0; //and start again
tft.setCursor(tftpos, 0); //reset text posn, color, size
tft.setTextSize(2);
tft.setTextColor(YELLOW);
tft.print(legends[i]);
tftpos += 12; // 2x System font width
old = i;
else {
b = &btns[old]; //last button is released
b->press(false);
if (b->justReleased()) b->drawButton(false);
The Adafruit_GFX_Button class is really nice to use. The TouchScreen library less so.
David.
