Hi sonnyyu, you seem to be the Dropbox/Arduino integration expert (among other skills) and therefore I think you can help me.
I haven't been able to install the Dropbox SDK on an Arduino Yun (it is up to date)
When I run
pip install dropbox
this is what I got in return
Collecting dropbox
/usr/lib/python2.7/site-packages/pip-9.0.1-py2.7.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#snimissingwarning.
SNIMissingWarning
/usr/lib/python2.7/site-packages/pip-9.0.1-py2.7.egg/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#insecureplatformwarning.
Could not fetch URL https://pypi.python.org/simple/dropbox/: There was a problem confirming the ssl certificate: [Errno 185090057] _ssl.c:340: error:0B084009:lib(11):func(132):reason(9) - skipping
Could not find a version that satisfies the requirement dropbox (from versions: )
No matching distribution found for dropbox
I have posted the question on Dropbox forum but got no useful answer. You are kind of last resource!!!
