Using Ds1302 RTC with Servo Motor
Hi, can someone help me to code for servo to move in a certain time depending on the RTC
// CONNECTIONS:
// DS1302 CLK/SCLK --> 5
// DS1302 DAT/IO --> 4
// DS1302 RST/CE --> 2
// DS1302 VCC --> 3.3v - 5v
// DS1302 GND --> GND
#include <RtcDS1302.h>
ThreeWire myWire(4,5,2); // IO, SCLK, CE
RtcDS1302<ThreeWire> Rtc(myWire);
void setup ()
    Serial.print("compiled: ");
    Serial.print(__DATE__);
    Serial.println(__TIME__);
    Rtc.Begin();
    RtcDateTime compiled = RtcDateTime(__DATE__, __TIME__);
    printDateTime(compiled);
    if (!Rtc.IsDateTimeValid())
        // Common Causes:
        //    1) first time you ran and the device wasn't running yet
        //    2) the battery on the device is low or even missing
        Serial.println("RTC lost confidence in the DateTime!");
        Rtc.SetDateTime(compiled);
    if (Rtc.GetIsWriteProtected())
        Serial.println("RTC was write protected, enabling writing now");
        Rtc.SetIsWriteProtected(false);
    if (!Rtc.GetIsRunning())
        Serial.println("RTC was not actively running, starting now");
        Rtc.SetIsRunning(true);
    RtcDateTime now = Rtc.GetDateTime();
    if (now < compiled)
        Serial.println("RTC is older than compile time!  (Updating DateTime)");
    else if (now > compiled)
        Serial.println("RTC is newer than compile time. (this is expected)");
    else if (now == compiled)
        Serial.println("RTC is the same as compile time! (not expected but all is fine)");
void loop ()
    printDateTime(now);
    delay(1000); // ten seconds
#define countof(a) (sizeof(a) / sizeof(a[0]))
void printDateTime(const RtcDateTime& dt)
    char datestring[26];
    snprintf_P(datestring,
            countof(datestring),
            PSTR("%02u/%02u/%04u %02u:%02u:%02u"),
            dt.Month(),
            dt.Day(),
            dt.Year(),
            dt.Hour(),
            dt.Minute(),
            dt.Second() );
    Serial.print(datestring);
I moved your topic to an appropriate forum category @jaaysquared.
In the future, please take some time to pick the forum category that best suits the subject of your topic. There is an "About the _____ category" topic at the top of each category that explains its purpose.
This is an important part of responsible forum usage, as explained in the "How to get the best out of this forum" guide. The guide contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Please edit your post to add code tags, and describe the problem.
For instructions on posting, read the "How to get the best out of this forum" post.
Sorry, first time posting topic here. Hope the edit helps my question
