Using EEPROM in loop
Hi!
I'm working on a project where I want to read a value from a potentiometer and after that save it to EEPROM.
Now I'm planning to use that saved value in the loop like this:
if(EEPROM.read == x){
  do y
So my question is if this is a good idea when the EEPROM has a life span of about 100 000 read/write functions?
As far as I know, it's writes not reads that are the problem.
And if you do an .update rather than a .write, it will only do a write if the value to be written differs from the one already there.
  do y
That will not compile. And it is not a loop.
if(EEPROM.read(address) == x){
  do y
The EEPROM is good for 100,000 write operations, read operations are unlimited.
groundFungus:
do y
  do y
OK. Just wondered because if I put that "if" statement in the loop it will read the EEPROM every time the loop runs. But if the read operations are unlimited that should not be a problem
Thanks for the answers!
