How can I use EEPROM while using RF24Mesh library, because the library stores some data in the EEPROM. So if I want to save some data, where I can save it to preserve the data saved by the library?
In EEPROM. What, specifically, is the problem?
The library saves the unique ID of the node in EEPROM as in the documentation of TMRh20 RF24Mesh library
This value, if changed, will be written to EEPROM on AVR so it will remain set, even after loss of power or code changes.
ahmednaoum:
for example, if the library saves some data in address 0 in eeprom, so if i write data in the same address, it will make some problems.
Then don't do that.
I don't understand what your question is, or problem is. Is if that you don't know where the library stores data in EEPROM, so you don't know what addresses you can't use?
