USING ESC WITH MOTOR SHIELD, PLAUSIBLE?
The problem I have run into is my ESC. I connected the 3 outputs to the motor, and connected the power input to the BEC and thus connected the BEC to my 9v-750mAH battery. The problem is I need to be able to bypass the potentiometer (which I can do through the code) but the other problem is my ESC having 7 cables (3 motor connectors, 2 main power connectors, and 2 signal cables) the signal cables are labeled S (for signal I think) and Ground. The tutorial shows there should be 3 cables. And I have no idea what to do. Im pretty sure ive tried everything.
