# Using ESP 32 with a program to run Room and coil sensor
**URL:** <https://forum.arduino.cc/t/using-esp-32-with-a-program-to-run-room-and-coil-sensor/1076436>\
**Category:** General Guidance\
**Created:** [January 12, 2023, 6:29am UTC](https://forum.arduino.cc/t/using-esp-32-with-a-program-to-run-room-and-coil-sensor/1076436 "2023-01-12T06:29:34Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![horace](https://dub1.discourse-cdn.com/arduino/user_avatar/forum.arduino.cc/horace/32/1014299_2.png) [@horace](https://forum.arduino.cc/u/horace)\
**Post date:** [January 12, 2023, 7:07am UTC](https://forum.arduino.cc/t/using-esp-32-with-a-program-to-run-room-and-coil-sensor/1076436/2 "2023-01-12T07:07:28Z")
</div>
have a read of [how-to-get-the-best-out-of-this-forum](https://forum.arduino.cc/t/how-to-get-the-best-out-of-this-forum/679966)
in particular you post is very difficult to read - use code tags\</\>
also avoid using images of screen output - copy the text and upload it
in the Arduino IDE select Fil;e\>Preferences and enable "Verbose output during Compiling and upload" then compile your program again
if there are problems upload the error messages as text
run the program and upload any serial monitor output which shows the problem as text (not an image)
_[View the full topic](https://forum.arduino.cc/t/using-esp-32-with-a-program-to-run-room-and-coil-sensor/1076436)._
