Hello there, would be brilliant if anyone could help me with my issue.
I have been looking around the internet and used tutorials for the ESP8266 setup. I am using a 5v to 3.3v regulator and if I manually send AT commands in the serial monitor the ESP8266 responds correctly and I can manually connect to the wifi router. (The end goal is to send sensor data to a webpage such as in this tutorial-https://www.instructables.com/id/Arduino-Esp8266-Post-Data-to-Website/)
I have tried various example code including the one in the tutorial. Yet when I try to use the code the ESP8266 seems to be unresponsive and no response is visible on the serial monitor. Why might this be??
Lewis
#include "SoftwareSerial.h"
String ssid ="My Router Name";
String password="Router Password";
SoftwareSerial esp(0, 1); // RX, TXString data;
String server = "lidiotnodal-monitors.000webhostapp.com/";
String uri = "/esppost.php"int DHpin = 8;//sensor pin
byte dat [5];
String temp ,hum;void setup() {
pinMode (DHpin, OUTPUT);
esp.begin(9600);
Serial.begin(9600);reset();
connectWifi();
}//reset the esp8266 module
void reset() {
esp.println("AT+RST");
delay(1000);if(esp.find("OK") ) Serial.println("Module Reset");
}//connect to your wifi network
void connectWifi() {
String cmd = "AT+CWJAP="" +ssid+"","" + password + """;
esp.println(cmd);
delay(4000);if(esp.find("OK")) {
Serial.println("Connected!");
}else {
connectWifi();
Serial.println("Cannot connect to wifi"); }
}byte read_data () {
byte data;
for (int i = 0; i < 8; i ++) {if (digitalRead (DHpin) == LOW) {
while (digitalRead (DHpin) == LOW); // wait for 50us
delayMicroseconds (30); // determine the duration of the high level to determine the data is '0 'or '1'
if (digitalRead (DHpin) == HIGH)
data |= (1 << (7-i)); // high front and low in the post
while (digitalRead (DHpin) == HIGH);
// data '1 ', wait for the next one receiver
} return data; }
void start_test () {
digitalWrite (DHpin, LOW); // bus down, send start signal
delay (30); // delay greater than 18ms, so DHT11 start signal can be detected
digitalWrite (DHpin, HIGH);
delayMicroseconds (40); // Wait for DHT11 response
pinMode (DHpin, INPUT);
delayMicroseconds (80);
// DHT11 response, pulled the bus 80us
if (digitalRead (DHpin) == LOW);
// DHT11 80us after the bus pulled to start sending data
for (int i = 0; i < 4; i ++)
// receive temperature and humidity data, the parity bit is not considered
dat = read_data ();
// send data once after releasing the bus, wait for the host to open the next Start signal
void loop () {
start_test ();
// convert the bit data to string form
hum = String(dat[0]);
temp= String(dat[2]);
data = "temperature=" + temp + "&humidity=" + hum;// data sent must be under this form //name1=value1&name2=value2.
httppost();
void httppost () {
esp.println("AT+CIPSTART="TCP","" + server + "",21"); //start a TCP connection.
if( esp.find("OK")) {
Serial.println("TCP connection ready");
} delay(1000);
String postRequest =
"POST " + uri + " HTTP/1.0\r\n" +
"Host: " + server + "\r\n" +
"Accept: " + "/" + "\r\n" +
"Content-Length: " + data.length() + "\r\n" +
"Content-Type: application/x-www-form-urlencoded\r\n" +
"\r\n" + data;
String sendCmd = "AT+CIPSEND=";//determine the number of caracters to be sent.
esp.print(sendCmd);
esp.println(postRequest.length() );
if(esp.find(">")) { Serial.println("Sending.."); esp.print(postRequest);
if( esp.find("SEND OK")) { Serial.println("Packet sent");
while (esp.available()) {
String tmpResp = esp.readString();
Serial.println(tmpResp);
// close the connection
esp.println("AT+CIPCLOSE");
[/quote]
