Hi I have a ESP8266 and want to use it to publish analog data from 0 to 5 volts I have it running on Wifi with a program that was intended to have a digital sensor. I also have had a a to d converter running and its fine but i need to run both.
I gather it can be done here are the both files.
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
If the code exceeds the 9000 character inline limit then attach it to a post
There is only 1 file, and I cannot see where you have made your best attempt. Don't expect to post our 2 codes and have someone combine them for you (You can offer it as paid work in the Gigs and Collaberations section).
Your whole attempt seems not correct. Assuming you are using an ESP that has pin A0 exposed (like a nodeMCU) You have to keep in mind that it may have a 0v - 1v level. Some of the development boards do have a voltage divider included check this link for it's usage.
