I recently picked up the Arduino Ethernet shield and I'm getting started on the first piece of my project.
I want to connect to http://www.nfl.com/liveupdate/scorestrip/scorestrip.json and return the text from that page. Currently it displays
{"ss":[["Sun","8:00","Pregame",,"ARI",,"NO",,,,"55760",,"PRE0","2012"]]}
Eventually I'll be using the data that is returned, but that part isn't important now.
I got the DNSWebClient Example code working and tried to modify it for my project. I just changed the URL for my needs.
DNS and DHCP-based Web client
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
#include
#include
// Enter a MAC address for your controller below.
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 };
char serverName[] = "www.nfl.com";
String location = "/~liveupdate/scorestrip/scorestrip.json HTTP/1.0";
// Initialize the Ethernet client library
EthernetClient client;
// start the serial library:
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(serverName, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET www.nfl.com/liveupdate/scorestrip/scorestrip.json HTTP/1.0");
client.println();
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while(true);
Here is what is displayed in the serial monitor.
connected
HTTP/1.0 400 Bad Request
Server: AkamaiGHost
Mime-Version: 1.0
Content-Type: text/html
Content-Length: 255
Expires: Sun, 22 Jul 2012 20:18:33 GMT
Date: Sun, 22 Jul 2012 20:18:33 GMT
Connection: close
Invalid URL
Invalid URL
The requested URL "www.nfl.com/liveupdate/scorestrip/scorestrip.json", is invalid.
Reference #9.1f4d1160.1342988313.0
disconnecting.
I'm don't fully understand what HTTP request I should be using. I haven't found a tutorial that explains how that code works and I'm not sure what I search for in order to find more information.
Any assistance is greatly appreciated. Thanks.
