Using Ethernet Shield Webserver To Control TVout Problem
Hello! So what i am trying to do, is have an interface on a webserver, so when you press a button on the webpage, it displays “Hello World!” on my TV. I have the TVout library (https://code.google.com/p/arduino-tvout/downloads/detail?name=TVout.zip&can=2&q=) using pins 7 and 8, and the ethernet shield using 10 11 12 13 (as always).
I used this code:
 Created by Rui Santos
 Visit: http://randomnerdtutorials.com for more arduino projects
 Arduino with Ethernet Shield
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
int led = 4;
Servo microservo;
int pos = 0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };   //physical mac address
byte ip[] = { 192, 168, 1, 178 };                      // ip in lan (that's what you need to use in your browser. ("192.168.1.178")
byte gateway[] = { 192, 168, 1, 1 };                   // internet access via router
byte subnet[] = { 255, 255, 255, 0 };                  //subnet mask
EthernetServer server(80);                             //server port
String readString;
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  pinMode(led, OUTPUT);
  microservo.attach(7);
  // start the Ethernet connection and the server:
  Ethernet.begin(mac, ip, gateway, subnet);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
         //if HTTP request has ended
         if (c == '\n') {
           Serial.println(readString); //print to serial monitor for debuging
           client.println("HTTP/1.1 200 OK"); //send new page
           client.println("Content-Type: text/html");
           client.println();
           client.println("<HTML>");
           client.println("<HEAD>");
           client.println("<meta name='apple-mobile-web-app-capable' content='yes' />");
           client.println("<meta name='apple-mobile-web-app-status-bar-style' content='black-translucent' />");
           client.println("<link rel='stylesheet' type='text/css' href='http://randomnerdtutorials.com/ethernetcss.css' />");
           client.println("<TITLE>Random Nerd Tutorials Project</TITLE>");
           client.println("</HEAD>");
           client.println("<BODY>");
           client.println("<H1>Random Nerd Tutorials Project</H1>");
           client.println("<hr />");
           client.println("
           client.println("<H2>Arduino with Ethernet Shield</H2>");
           client.println("
           client.println("<a href=\"/?button1on\"\">Turn On LED</a>");
           client.println("<a href=\"/?button1off\"\">Turn Off LED</a>
           client.println("
           client.println("
           client.println("<a href=\"/?button2on\"\">Rotate Left</a>");
           client.println("<a href=\"/?button2off\"\">Rotate Right</a>
           client.println("<p>Created by Rui Santos. Visit http://randomnerdtutorials.com for more projects!</p>");
           client.println("
           client.println("</BODY>");
           client.println("</HTML>");
           delay(1);
           //stopping client
           client.stop();
           //controls the Arduino if you press the buttons
           if (readString.indexOf("?button1on") >0){
               digitalWrite(led, HIGH);
           if (readString.indexOf("?button1off") >0){
               digitalWrite(led, LOW);
           if (readString.indexOf("?button2on") >0){
                for(pos = 0; pos < 180; pos += 3)  // goes from 0 degrees to 180 degrees
                {                                  // in steps of 1 degree
                  microservo.write(pos);              // tell servo to go to position in variable 'pos'
                  delay(15);                       // waits 15ms for the servo to reach the position
           if (readString.indexOf("?button2off") >0){
                for(pos = 180; pos>=1; pos-=3)     // goes from 180 degrees to 0 degrees
            //clearing string for next read
            readString="";
(http://randomnerdtutorials.com/arduino-webserver-with-an-arduino-ethernet-shield/)
to test the webserver, and i hooked up the LED, and everything worked fine.
AND
I used this code:
#include <TVout.h>
TVout TV;
unsigned char x, y;
void setup ( )
  TV.start_render( _NTSC );
void loop ( )
  TV.clear_screen ( );
  TV.print_str ( 10, 10, "I love" );
  TV.print_str ( 10, 20, "electronics," );
  TV.print_str ( 10, 30, "computers, and" );
  TV.print_str ( 10, 40, "microcontrollers!" );
  TV.delay ( 60 );
(http://www.instructables.com/id/Ubuntu-and-the-arduino/step7/Get-video-from-your-Arduino/)
to test the video out, and it worked fine.
But i combined the two so when you would usually press the on button for the led to turn on, it displayes the text.
Heres the code:
(all i did i take out the HIGH of the led pin and replaced it with the code that displays characters on the screen, and added the ints and library imports.)
#include <TVout.h>
TVout TV;
unsigned char x, y;
#include <SPI.h>
#include <Servo.h>
int led = 4;
Servo microservo;
int pos = 0;
String readString;
   while (!Serial) {
  server.begin();
  if (client) {
          readString += c;
          //Serial.print(c);
         if (c == '\n') {
           client.println();
           client.println("
           client.println("
           client.println("
           client.println("
           client.println("
           delay(1);
           //stopping client
           client.stop();
              TV.print_str ( 10, 40, "Hello World!" );
              TV.delay ( 60 );
            readString="";
Thanks for the help in advace!
-Scott
Unless you have a Mega, you ran out of memory about 4000 bytes ago. Use the F() macro
Serial.print(F("server is at "));
around ALL your (excessive number of) string literals.
I dont think i did, but heres a smaller code that does the same:
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <TVout.h>
TVout TV;
unsigned char x, y;
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte subnet[] = { 255, 255, 0, 0 }; //subnet mask
EthernetServer server(80);; //server port
String readString;
void setup(){
  pinMode(4, OUTPUT); //pin selected to control
  //start Ethernet
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  server.begin();
  //enable serial data print
  Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == '\n') {
          Serial.println(readString); //see what was captured
          //now output HTML data header
          client.println();
          client.println("<TITLE>Arduino GET test page</TITLE>");
          client.println("<H1>HTML form GET example</H1>");
          client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
          client.println("Pin 5 'on5' or 'off5': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
          client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
          client.println("</FORM>");
          client.println("
          delay(1);
          //stopping client
          client.stop();
          if(readString.indexOf("on4") >0)//checks for on
            digitalWrite(4, HIGH);    // set pin 5 high
            Serial.println("Led On");
  TV.delay ( 60 );
          if(readString.indexOf("off4") >0)//checks for off
            digitalWrite(4, LOW);    // set pin 5 low
            Serial.println("Led Off");
          readString="";
I know its working, because when i execute the commmand, the LED turns on, but no screen output, and what do you mean by the F() macro? Thanks.
I dont think i did
OK, fine. Forget that I tried to help.
Just to be sure, though, check this page out.
http://playground.arduino.cc/Code/AvailableMemory
Incorporate the test for available memory in your code. Then, use the F() macro as I showed in the example. Run the sketch again. What do you see for available memory in each case?
Have you gotten any code to work using the TVout.h library?
I have, i got it to work with the ethernet shield on also, if that helps any saying that.
