I have been trying to get external EEPROM chips to work with arduino now for several days without luck. I have been crawling arduino.cc with google and tried without success dronebotworkshops tutorial, Gammon I2C, HobbyTronics and several others for guidance but nothing seems to work. Using Unoes internal EEMPROM works well.
I have tried My-MS 24C01, 24LC025 and 24AA02 chips but none seems to work as wanted. With 24LC025 I have tried multiple different chips with no apparent results.
I have tried several different code bases (all based on wire.h for I2C communication) from straightforward examples to self made code. Several version of the code is tried two Unoes and one Leonardo to rule out burned boards/pins. I think Leonardo might have some problem with fried pins but the Unoes seems to be fine running other I2C project that utilizes DTS22, OLED display and an RTC clock which still seems to work.
Pins on the left (A0-A2, Vss) are grounded, Vcc is connected to power, RW has been tried in power, ground and with digital high and low. In Unoes SCL is connected to A5 and SDA to A4 and are using 4,5kOhm resistors.
I wrote this serval years ago written to test the AT24C1024B 128K bytes EEPROM:-
Memory test by Mike Cook Feb 2012
Test my hacked Master I2C library
added I2c.write2(address, reg 1, reg 2, *data, number of bytes)
added reg 2 and changed number of bytes from a byte to a int
I2c.setSpeed(n) now takes 2 for 800 KHz and 3 for 1MHz
Written to test the AT24C1024B 128K bytes EEPROM
This code will handle up to four devices on the same bus
// include the library code:
#include <I2C.h>
int memoryAddresBase = 0x50;
// there are 512 pages per chip and a maximum of 4 chips on the bus at the same time
// the top bit of the chip's page address is the lowest bit of the I2C device address
// the next two bits of the I2C device address define what chip is addressed
// thereore with four chips you have 512 * 4 = 2048 pages of 256 bytes per page giving 512K bytes of memory
int page = 2; // the 256 byte page of memory to write a test pattern to
I2c.begin();
I2c.setSpeed(2); // I can only get my hardware to work at 800KHz but the data sheet says it should work at 1MHz
testPage(page); // write data to the selected page
displayPage(page); // display data to see it arrived correctly
void loop() { // nothing to do it is all in the setup()
void testPage(int pg){ // write a page of data to the EEPROM
int address;
long int time;
uint8_t buffer[255];
// test data - the inverse of the byte count
for(int i= 0; i<256; i++) buffer[i] = 255 - i; // fill up the buffer used for the page write
Serial.print(" writing memory page ");
Serial.println(pg, HEX);
address = memoryAddresBase | ( pg >> 8);
time = millis(); // make a note of the time now
while(I2c.write2(address, pg & 0xff, 0, buffer, 256) != 0 ) { } // repeat until command is taken
while(I2c.write(address,pg & 0xff, 0) != 0) { } // repeat until it is free - for timing purpouses only
time = millis() - time; // work out how long it took
Serial.print(" this took ");
Serial.print(time);
Serial.println("mS ");
void displayPage(int pg){ // display a page of data from the EEPROM
int c, address;
Serial.print(" reading memory page ");
address = memoryAddresBase | ( pg >> 8); // create the I2C address of the chip to use
for(int i=0; i<16; i++){
while(I2c.write(address,pg & 0xff, i<<4) != 0) { } // set up start of read
Serial.print(i, HEX); // print most significant nibble of address
Serial.print(" ");
I2c.read(address, 16); // request 16 bytes from memory device ( note maximum buffer size is 32 bytes )
for(int j=0; j<16; j++){ // now get the bytes one at a time
c = I2c.receive(); // receive a byte
if(c < 0x10) Serial.print("0"); // print leading zero if needed
Serial.print(c, HEX); // print the byte
Serial.print(" ");
Serial.println(" "); // new line
Is I2C.h general Arduino library? My IDE gave an error about not finding it and I cannot find that header from my Arduino paths. Only from general kernel / raspian paths like /usr/include/linux/i2c.h
No.
The notes in the code says:-
Test my hacked Master I2C library.
So you need to find the "Master I2C library". The problem with the standard one is the limited size of the buffer. The Master I2C library has a buffer limit set at 255 so I hacked to make it 256.
Ok, got too exited to test something new that might work Need to find that library then.
Gave now also a shot with [Sparkfun's EEPROM library](https://github.com/sparkfun/SparkFun_External_EEPROM_Arduino_Library) but it also gives false results.
You are using code with a two byte memory address used with a larger eeprom, but you have a small eeprom with only 256 bytes of memory. The device is organized as a single block of 256 x 8-bit memory.
