I am trying to write a sketch that measures the speed of a metal ball rolling down a track. I have an led and photo-transistor which is placed across the track. When the light is not blocked, the input from the photo-transistor(pin 19) is low, when light is blocked it is high. First I need to measure the time the led is blocking the photo-transistor. I am trying to use an Interrupt service routine to do this.
I am trying to interrupt when the led pin is going from low to high, take a time measurement, interrupt again when going from high to low, take a time measurement and determine delta time. Here is my code:
I am very new to Arduino and programming in general. I would really appreciate it if someone could have a look and tell me if I am making some major mistakes, Thanks.
Also serial communications does not function inside an interrupt function as all interrupts are disabled at that time.
You should most likely only require one interrupt, the finished led/sensor. You can just loop in the main loop function testing the start led/sensor and when tripped capture the starting time and then wait for the finished interrupt sensor to set a flag variable the it has triggered and then again get the current time and subtract the difference to get the delta time between those two sensors and send the serial data out.
retrolefty:
Thanks for you help,
I have tried to follow what you told me, just wondering am I going the right way?
//Pin assignments
#define led_bottom 19 //led pin
int long unsigned time_1; //initial time
int long unsigned time_2; //final time
int counter =0;
void setup () {
pinMode(led_bottom, INPUT);
digitalWrite(led_bottom, HIGH);
attachInterrupt(4, bottom_interrupt, FALLING);
void loop(){
if (digitalRead(led_bottom)>0.2) {
time_1=micros();
Serial.print("T1= ");
Serial.println(time_1);
if (counter >0) {
time_2=micros();
Serial.print("T2= ");
Serial.println(time_2);
Serial.print("T= ");
Serial.println(time_2-time_1);
counter=0;
void bottom_interrupt () { //led rising
counter++;
This makes no sense: digitalRead(led_bottom)>0.2)
A digitalRead() returns a high or low not a float value.
Do all your printing at the end after the finish, just save the start time in a variable to print along with the finish time and duration time calculation after the finish event.
There should probably be some timeout function in case the finish never happens.
I have changed this to digitalRead(led_bottom)==1
retrolefty:
Yes I will do this, where exactly is the best place to print?
//Pin assignments
volatile int counter =0;
void setup () {
void loop(){
if (digitalRead(led_bottom)==1) {
time_1=millis();
//delay(10);
if (counter >0) {
time_2=millis();
counter=0;
counter++;
In the first if loop, time_1 is being read 1-3 times and displayed on the serial monitor. The delta time calculation is carried out with the last time_1 value and not the first, how can I have this if loop executed only once?
retrolefty:
Where can I find a timeout function?
Thanks so much for you help, really appreciate it.
