Hello,
I'm currently trying to make a gluing machine using stepper motors and a lead screw to move a plunger used to press on a tube of glue. I want to put a limit switch at the end of the lead screw that will be triggered when the glue is empty. I am using interrupts to code the limit switch, because I wasn't this to take priority once it is pressed to prevent breaking something. But I'm running into a problem. When the limit switch is triggered it is suppose to stop any motion further and retract the plunger a few rotations. But when the limit switch is pressed it stops the motion but doesn't retract and it locks up everything and nothing else can be done until the restart button is pressed. I'm just wondering what I can do to make the limit switch work and retract.
Thank you!
Thomas
//Testing Buttons with LCD and New Motors
#include <Stepper.h>
#include <LiquidCrystal.h>
//setting up led
int greenLed = 52;
int redLed = 50;
// Setting up int for the control buttons
int glueButton = 53;
int pulseButton = 51;
int upButton = 49;
int downButton = 47;
int emptyLimitSwitch = 2;
// Setting up int for glueing motor
int in1Pin = 6;
int in2Pin = 5;
int in3Pin = 4;
int in4Pin = 3;
const int stepsPerRev = 200;
Stepper glueStepper (stepsPerRev, in1Pin, in2Pin, in3Pin, in4Pin);
// Setting up Constants for LCD
const int rs = 7, en = 8, d4 = 9, d5 = 10, d6 = 11, d7 = 12;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//Activating LCD letting the arduino know the LCD is 16 characters x 2 Rows
lcd.begin(16, 2);
//Activating stepper and setting pin mode
pinMode(in1Pin, OUTPUT);
pinMode(in2Pin, OUTPUT);
pinMode(in3Pin, OUTPUT);
pinMode(in4Pin, OUTPUT);
pinMode(glueButton, INPUT_PULLUP);
pinMode(pulseButton, INPUT_PULLUP);
pinMode(upButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
pinMode(emptyLimitSwitch, INPUT_PULLUP);
pinMode(greenLed, OUTPUT);
pinMode(redLed, OUTPUT);
digitalWrite(greenLed, HIGH); //turning on green led
attachInterrupt(digitalPinToInterrupt(emptyLimitSwitch), empty, LOW);
//reading pot values and assinging value to a name, mapping the pots to chosen range
int pulseValue = analogRead(A0);
int pulseStep = map(pulseValue, 0, 1023, 0, 500);
int glueStepValue = analogRead(A1);
int glueStep = map(glueStepValue, 0, 1023, 0, 1000);
int glueRpmValue = analogRead(A2);
int glueRpm = map(glueRpmValue, 0, 1023, 0, 201);
int rpmValue = analogRead(A3);
int rpm = map(rpmValue, 0, 1023, 0, 5);
//printing the pot values to the lcd screen and moving cursor and printing blanks to refresh the screen
lcd.print("P=");
lcd.setCursor(2, 0),
lcd.print(" ");
lcd.setCursor(2, 0);
lcd.print(pulseStep);
lcd.setCursor(6, 0);
lcd.print("Gstp=");
lcd.setCursor(11, 0),
lcd.print(" ");
lcd.print(glueStep);
lcd.setCursor(0, 1);
lcd.print("Grpm=");
lcd.setCursor(5, 1),
lcd.print(" ");
lcd.print(glueRpm);
lcd.setCursor(8, 1);
lcd.print("RPM=");
lcd.setCursor(12, 1),
lcd.print(" ");
lcd.print(rpm);
lcd.setCursor(0, 0);
//reading button values
int glueButtonValue = digitalRead(glueButton);
int pulseButtonValue = digitalRead(pulseButton);
int upButtonValue = digitalRead(upButton);
int downButtonValue = digitalRead(downButton);
int emptyLimitSwitchValue = digitalRead(emptyLimitSwitch);
//button code
if (glueButtonValue == LOW)
glueStepper.setSpeed(glueRpm);
glueStepper.step(-1500 - glueStep);
glueStepper.step(800);
delay(250);
if (pulseButtonValue == LOW)
glueStepper.step (-pulseStep);
if (upButtonValue == LOW)
glueStepper.setSpeed(275);
glueStepper.step(500);
if (downButtonValue == LOW)
glueStepper.step(-500);
if (emptyLimitSwitchValue == LOW)
glueStepper.setSpeed(250);
glueStepper.step(1000);
void empty() {
if (emptyLimitSwitchValue == LOW) {
glueStepper.setSpeed(200);
glueStepper.step(5000);
