Using external power source
Once the sketch (program) is uploaded to the Arduino, it will run stand alone as long as you provide power. There is no adjustment needed to make it run without the PC unless you're communicating between the two using serial. Even then, if you're just sending debugging output using serial it doesn't matter to the arduino whether there is a PC there listening.
