I'm trying to set up my first board with the Leonardo firmware and basic design concepts.
For what I need I'm short 1 digital pin and I want to pinch it from somewhere. I also want to keep the standard Leonardo firmware/bootloader because changing the firmware is above my skill level.
My thoughts on where to get the extra digital output include:
HWB
TXLED
RXLED
Or can I convert an analog pin to digital?
Any ideas which would be the easiest to use and how to keep it compatible with the current Leonardo firmware??
I don't own a Leonardo board but I suspect like most all the other arduino boards, analog input pins can be used as digital pins, just use the analog pin names in the digital commands:
Should I then permanently connect pin 33 HWB to ground via 10K resistor as shown on the Leonardo schematic? Or will this cause the bootloader to keep resetting?
Thanks for this info. I have a project on an Arduino Pro Mini where I was 2 pins short (everyone appreciates an audible alarm and then a button to silence/acknowledge it!).
Now I will repurpose all 6 of the analog inputs as digital inputs and leave pins 1 & 2 available for serial communications in the future (Should I need it). That's puts me up 2 pins now!
I won't even mess with the two 'bonus' analog pins in the center of the board.
