Using extra serial pins on mega board
This may be a dumb question, but in order to use RX/TX1, RX/TX2 and RX/TX3 on a mega board do I use the software serial library? I guess I get confused when people say the mega board has 3 extra sets of RX/TX pins, but as far as I can tell, I don't see any way to access those extra pins using the normal serial library or even anything to say whether the atmel chip treats those pins any differently than any other pins.
You access it using the hardware serial library using the following names for the ports:
Port Name Transmit Pin Receive Pin Serial 1(Also USB) 0 (Also USB) Serial1 18 19 Serial2 16 17 Serial3 14 15
Great, thanks!
Bruce
Is it possible to use serial1 instead of serial to load program? I would like to use one serial for xbee, other for usb and third for gps... But both serials ( serial and serial 1 ) should be for program loading into arduino mega.
Thank you in advance for help
D.
You can't have anything plugged into Serial when uploading firmware, figured that out after trying to use a Sparkfun BlueSmirf serial adaptor to upload code wirelessly (would have been cool but it doesn't work).
In theory yes, but you'd have to modify the boot loader. But with an extra 3 ports is there any need to?
