Hi everyone,
I’ve been looking for ways to create a (single channel) multi-band audio visualizer on an I2C OLED display that I bought, and I came across this IC from sparkfun that essentially takes an analog audio input and converts it to a DC representation of a set of particular frequencies.
I was wondering if I could essentially recreate this in code, using the A0 input on the arduino that I have. I’ve looked into using things like FFT and FHT, and while useful, seemed very complicated and a bit out of my understanding. I attempted to create a demo visualizer using the FHT library, however the set of outputs that I received from FHT just seemed to be completely inaccurate, possibly meaning that I’m doing something wrong in my code. If someone would take a look at it, that’d be great:
#define LOG_OUT 1 // use the log output function
#define FHT_N 256 // set to 256 point fht
#include <FHT.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
Adafruit_SSD1306 display(6);
int freqs[8] = {0,0,0,0,0,0,0,0};
Serial.begin(115200)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
TIMSK0 = 0; // turn off timer0 for lower jitter
ADCSRA = 0xe5; // set the adc to free running mode
ADMUX = 0x40; // use adc0
DIDR0 = 0x01; // turn off the digital input for adc0
while(1) { // reduces jitter
cli(); // UDRE interrupt slows this way down on arduino1.0
for (int i = 0 ; i < FHT_N ; i++) { // save 256 samples
while(!(ADCSRA & 0x10)); // wait for adc to be ready
ADCSRA = 0xf5; // restart adc
byte m = ADCL; // fetch adc data
byte j = ADCH;
int k = (j << 8) | m; // form into an int
k -= 0x0200; // form into a signed int
k <<= 6; // form into a 16b signed int
fht_input[i] = k; // put real data into bins
fht_window(); // window the data for better frequency response
fht_reorder(); // reorder the data before doing the fht
fht_run(); // process the data in the fht
fht_mag_log(); // take the output of the fht
sei();
memset(freqs, 0, sizeof(freqs));
for(int i = 0; i< sizeof(fht_log_out); i++){ //add freq to range pool
Serial.print(String(fht_log_out[i]) + " ");
freqs[i/16] += fht_log_out[i];
for(int i = 0; i< 8; i++){
display.fillRect(i*16,0,16,freqs[i]/16,1); //take avg freq of each pool
display.display();
The FHT from OpenMusicLabs works perfectly. How would you know from your example that the output “seemed to be completely inaccurate”, unless you have a standard to compare it to?
When testing unfamiliar code, you need to prepare an example where you know what to expect, and make sure that the results are as expected. For example, to test the FFT routines, I wrote the following, and it works fine. Try it.
fft_test_sine
example sketch for testing the fft library.
This generates a simple sine wave data set consisting
of two sine waves of frequency f1 and f2, transforms it, calculates
and prints the amplitude of the transform.
// do #defines BEFORE #includes
#define LIN_OUT 1 // use the lin output function
#define FFT_N 64 // set to 64 point fft
#include <FFT.h> // include the library
Serial.begin(9600); // output on the serial port
int i,k;
float f1=2.0,f2=5.0; //the two input frequencies (bin values)
for (i = 0 ; i < FFT_N ; i++) { // create samples
// amplitudes are 1000 for f1 and 500 for f2
k=1000*sin(2*PI*f1*i/FFT_N)+500.*sin(2*PI*f2*i/FFT_N);
fft_input[2*i] = k; // put real data into even bins
fft_input[2*i+1] = 0; // set odd bins to 0
fft_window(); //Try with and without this line, it smears
fft_reorder(); // reorder the data before doing the fft
fft_run(); // process the data using the fft
fft_mag_lin(); // calculate the magnitude of the output
// print the frequency index and amplitudes
Serial.println("bin amplitude");
for (i=0; i<FFT_N/2; i++) {
Serial.print(i);
Serial.print(" ");
Serial.println(2*fft_lin_out[i]); //*2 for "negative frequency" amplitude
Serial.println("Done");
while(1); //wait here
PS: don’t forget the Sampling Theorem – ignoring the rules can make the results nearly uninterpretable.
Finally, what is the following code supposed to do?
That lower code block there is used to firstly reset the freqs array back to a set of zeroes, then fit all of the (128, I believe) sets of outputs from FHT into a set of 8 different pools of bands. Later on in the code I divide to basically get the average value of each of the outputs added together before.
As for the FHT library itself, I'm sure it works perfectly - I'm just not sure what I'm doing wrong with either the setup or the way I'm reading the outputs. What I'm getting so far (on my display, and by extension, my array) is a set of bands that move independently, whether or not an audio input is connected. I'm not using any amplification yet, but the source I'm using should be strong enough to at least produce some visible change, which it isn't. Perhaps I'm missing some use of that sampling theorem you mentioned, but I'm not completely sure.
