Using file with ESP32 or teensy 4.0
I have this function it works without any problem as a c code, I am asking if I need to run it(and the rest of my code) on the esp32 or teensy4.0 how can I deal with the files?
int write_header(FILE *f) {
     int i, j, byte = 0,
         size = sizeof(unsigned int) + 1 +
              num_active * (1 + sizeof(int));
     unsigned int weight;
     char *buffer = (char *) calloc(size, 1);
     if (buffer == NULL)
         return MEM_ALLOC_FAIL;
     j = sizeof(int);
     while (j--)
         buffer[byte++] =
             (original_size >> (j << 3)) & 0xff;
     buffer[byte++] = (char) num_active;
     for (i = 1; i <= num_active; ++i) {
         weight = nodes[i].weight;
         buffer[byte++] =
             (char) (-nodes[i].index - 1);
         j = sizeof(int);
         while (j--)
             buffer[byte++] =
                 (weight >> (j << 3)) & 0xff;
     fwrite(buffer, 1, size, f);
     free(buffer);
     return 0;
Consider a few points
Thank you for all, I will use "SPIFFS.h"
Now my question how to use like this function write() in Arduino ide? because this function deal with binary.
SPIFFS is already deprecated.
You should either use LittleFS.h or the SD-card
What is the problem with using the SD-Card?
A Teensy 4.1 has even the SD-Card-socket on the microcontroller-board
I do not have SD card now, therefore I will use SPIFFS.h,
why SPIFFS is already deprecated?
You can use SPIFFs but you are in danger that after updating the ESP32-corefiles SPIFFs can be removed. The more comfortable successor of SPIFFS is LittleFS which IS already inside the ESP32-core.
Just do a google search for ESP32 LittleFS.h
There is trap with the library-names
LITTLESF.h is the filename of the library for ESP8266
LittleFS.h is the filename for ESP32
I took this ESP8266 code
https://raw.githubusercontent.com/lorol/LITTLEFS/master/examples/LITTLEFS_test/LITTLEFS_test.ino
and renamed all LITTLESF to LittleFS
After that modification is does compile for ESP32
here is the code
#include <Arduino.h>
#include "FS.h"
//#include <LITTLEFS.h> // CAPITAL-letters is the library for ESP8266
#include <LittleFS.h> // lowcase LittleFS.h is for ESP32
/* You only need to format LITTLEFS the first time you run a
   test or else use the LITTLEFS plugin to create a partition
   https://github.com/lorol/arduino-esp32littlefs-plugin
   If you test two partitions, you need to use a custom
   partition.csv file, see in the sketch folder */
//#define TWOPART
#define FORMAT_LITTLEFS_IF_FAILED true
void listDir(fs::FS &fs, const char * dirname, uint8_t levels) {
  Serial.printf("Listing directory: %s\r\n", dirname);
  File root = fs.open(dirname);
  if (!root) {
    Serial.println("- failed to open directory");
    return;
  if (!root.isDirectory()) {
    Serial.println(" - not a directory");
    return;
  File file = root.openNextFile();
  while (file) {
    if (file.isDirectory()) {
      Serial.print("  DIR : ");
      Serial.println(file.name());
      if (levels) {
        listDir(fs, file.name(), levels - 1);
      Serial.print("  FILE: ");
      Serial.print(file.name());
      Serial.print("\tSIZE: ");
      Serial.println(file.size());
void createDir(fs::FS &fs, const char * path) {
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path)) {
    Serial.println("Dir created");
    Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char * path) {
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path)) {
    Serial.println("Dir removed");
    Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char * path) {
  Serial.printf("Reading file: %s\r\n", path);
  File file = fs.open(path);
  if (!file || file.isDirectory()) {
    Serial.println("- failed to open file for reading");
    return;
  Serial.println("- read from file:");
  while (file.available()) {
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Writing file: %s\r\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("- failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("- file written");
    Serial.println("- write failed");
  file.close();
void appendFile(fs::FS &fs, const char * path, const char * message) {
  Serial.printf("Appending to file: %s\r\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("- failed to open file for appending");
    return;
    Serial.println("- message appended");
    Serial.println("- append failed");
  file.close();
void renameFile(fs::FS &fs, const char * path1, const char * path2) {
  Serial.printf("Renaming file %s to %s\r\n", path1, path2);
  if (fs.rename(path1, path2)) {
    Serial.println("- file renamed");
    Serial.println("- rename failed");
void deleteFile(fs::FS &fs, const char * path) {
  Serial.printf("Deleting file: %s\r\n", path);
  if (fs.remove(path)) {
    Serial.println("- file deleted");
    Serial.println("- delete failed");
// SPIFFS-like write and delete file, better use #define CONFIG_LITTLEFS_SPIFFS_COMPAT 1
void writeFile2(fs::FS &fs, const char * path, const char * message) {
  if (!fs.exists(path)) {
    if (strchr(path, '/')) {
      Serial.printf("Create missing folders of: %s\r\n", path);
      char *pathStr = strdup(path);
      if (pathStr) {
        char *ptr = strchr(pathStr, '/');
        while (ptr) {
          *ptr = 0;
          fs.mkdir(pathStr);
          *ptr = '/';
          ptr = strchr(ptr + 1, '/');
      free(pathStr);
  Serial.printf("Writing file to: %s\r\n", path);
  if (!file) {
    return;
  file.close();
void deleteFile2(fs::FS &fs, const char * path) {
  Serial.printf("Deleting file and empty folders on path: %s\r\n", path);
  if (pathStr) {
    char *ptr = strrchr(pathStr, '/');
    if (ptr) {
      Serial.printf("Removing all empty folders on path: %s\r\n", path);
    while (ptr) {
      *ptr = 0;
      fs.rmdir(pathStr);
    free(pathStr);
void testFileIO(fs::FS &fs, const char * path) {
  Serial.printf("Testing file I/O with %s\r\n", path);
  static uint8_t buf[512];
  size_t len = 0;
  if (!file) {
    return;
  size_t i;
  Serial.print("- writing" );
  uint32_t start = millis();
  for (i = 0; i < 2048; i++) {
    if ((i & 0x001F) == 0x001F) {
      Serial.print(".");
    file.write(buf, 512);
  Serial.println("");
  uint32_t end = millis() - start;
  Serial.printf(" - %u bytes written in %u ms\r\n", 2048 * 512, end);
  file.close();
  start = millis();
  end = start;
  i = 0;
  if (file && !file.isDirectory()) {
    len = file.size();
    size_t flen = len;
    start = millis();
    Serial.print("- reading" );
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      if ((i++ & 0x001F) == 0x001F) {
        Serial.print(".");
      len -= toRead;
    Serial.println("");
    Serial.printf("- %u bytes read in %u ms\r\n", flen, end);
    file.close();
#ifdef TWOPART
  if (!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED, "/lfs2", 5, "part2")) {
    Serial.println("part2 Mount Failed");
    return;
  appendFile(LittleFS, "/hello0.txt", "World0!\r\n");
  readFile(LittleFS, "/hello0.txt");
  LittleFS.end();
  Serial.println( "Done with part2, work with the first lfs partition..." );
#endif
  if (!LittleFS.begin(FORMAT_LITTLEFS_IF_FAILED)) {
    Serial.println("LITTLEFS Mount Failed");
    return;
  Serial.println( "SPIFFS-like write file to new path and delete it w/folders" );
  writeFile2(LittleFS, "/new1/new2/new3/hello3.txt", "Hello3");
  listDir(LittleFS, "/", 3);
  deleteFile2(LittleFS, "/new1/new2/new3/hello3.txt");
  createDir(LittleFS, "/mydir");
  writeFile(LittleFS, "/mydir/hello2.txt", "Hello2");
  listDir(LittleFS, "/", 1);
  deleteFile(LittleFS, "/mydir/hello2.txt");
  removeDir(LittleFS, "/mydir");
  writeFile(LittleFS, "/hello.txt", "Hello ");
  appendFile(LittleFS, "/hello.txt", "World!\r\n");
  readFile(LittleFS, "/hello.txt");
  renameFile(LittleFS, "/hello.txt", "/foo.txt");
  readFile(LittleFS, "/foo.txt");
  deleteFile(LittleFS, "/foo.txt");
  testFileIO(LittleFS, "/test.txt");
  deleteFile(LittleFS, "/test.txt");
  Serial.println( "Test complete" );
best regards Stefan
Please I have this array
how can write it in file ? I used f.write(buffer, size);
but I got on this error :
invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
char *buffer is not an array it is a pointer to a char
Me personal I prefer to use the library-SafeString.
With the SafeString-library I define the a variable of type Safestring and all pointer pointing boundary checking etc. is done automatically inside the library
At least without seeing your complete sketch only wild guessings about you might make it work can be poted
best regards Stefan
