Hello all,
I’ve been working on a project using the ESP8266 with an Arduino UNO for a few days now. The hope is that the Arduino, sending AT commands to the ESP-01, can start a softAP that requests a form, and then the Arduino can read the form that is sent back. However, when I try to use find() after receiving the data, it doesn’t work. I receive “IDP” but everything after that doesn’t read. I should add that when I first request the webpage, find(“GET / HTTP”) works as expected, but after that find(“GET /getData?”) or even “GET” doesn’t work. Any ideas?
#include <EEPROM.h>
#include <SoftwareSerial.h>
SoftwareSerial wifiModule(2, 3);
boolean first;
unsigned long currentTime = millis();
unsigned long previousTime = 0;
EEPROM.begin();
wifiModule.begin(9600);
Serial.println("Resetting EEPROM");
if(EEPROM.read(96) == 0) {
for(int i = 0; i < EEPROM.length(); i++) {
EEPROM.write(i, 0);
Serial.println("Reset EEPROM successfully");
//checks if SSID is null, if so start setup process
if(EEPROM.read(0) == 0) {
first = true;
first = false;
if(first == true) {
sendData("AT+CWMODE=2", 50); // configure as access point
sendData("AT+CWSAP=\"testserver\",\"hello12345\",5,3", 100); // start ap
sendData("AT+CIPMUX=1", 50); // needed for server to work properly
sendData("AT+CIPSERVER=1,80", 50); // turn on server on port 80
sendData("AT+CIFSR", 50);
String sendData(String command, int responseTime) {
String response = "";
wifiModule.println(command);
long int time = millis();
while ((time+responseTime) > millis()) {
while(wifiModule.available()) {
char c = wifiModule.read();
response += c;
Serial.println("Response: " + response);
return response;
if(first == true) {
if(wifiModule.find("+IPD,")) {
delay(1000); //delay required for 9600 baud
int connectionId = wifiModule.read() - 48; // -48 because .read() return decimal, 0 in decimal is 48
Serial.print("IPD with id ");
Serial.println(connectionId);
if(wifiModule.find("GET / HTTP")) {
Serial.println("Client detected");
String webpage = "<!DOCTYPE html><html><body><form action='getData' method='GET'><input type='text' name='ssid' placeholder='Network'><input type='password' name='pass' placeholder='Passcode'><input type='submit'></form></body></html>";
String cipSend = "AT+CIPSEND=";
cipSend += connectionId;
cipSend += ",";
cipSend += webpage.length();
cipSend += "\r\n";
sendData(cipSend, 1000);
sendData(webpage, 2000);
String closeCommand = "AT+CIPCLOSE=";
closeCommand+=connectionId; // append connection id
closeCommand+= "\r\n";
sendData(closeCommand, 3000);
} else if(wifiModule.find("GET /getData?")) {
Serial.println("Received Data");
String webpage = "<!DOCTYPE html><html><body><h1>Successful transmission, thank you</h1></body></html>";
cipSend += ",";
cipSend += "\r\n";
sendData(webpage, 1000);
//for debugging purposes
while(Serial.available()) {
wifiModule.write(Serial.read());
Serial.write(wifiModule.read());
Thanks!
