Using Fingerprint Scanner And Bluetooth with Arduino
I am trying to use fingerprint sensor r307 and Bluetooth module hco5 with Arduino . The code is compiling and uploading properly but when i execute it it is able to detect fingerprint sensor but is not able to receive messages from Bluetooth module. Bluetooth work with these lines emitted out…
 mySerial.begin(9600);
  while (!Serial);  // For Yun/Leo/Micro/Zero/...
  delay(100);
  Serial.println("\n\nAdafruit finger detect test");
  // set the data rate for the sensor serial port
  finger.begin(57600);
  if (finger.verifyPassword()) {
    Serial.println("Found fingerprint sensor!");
    Serial.println("Did not find fingerprint sensor :(");
    while (1) {
      delay(1);
  finger.getTemplateCount();
  Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
  Serial.println("Waiting for valid finger...");
but i need them, especially
here is my code
#include <SoftwareSerial.h>// import the serial library
#include <Adafruit_Fingerprint.h>
SoftwareSerial mySerial(4,5);
SoftwareSerial bt(2, 3); // RX, TX
int ledpin = 13; // led on D13 will show blink on / off
int BluetoothData; // the data given from Computer
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
  bt.begin(9600);
  delay(100);
    while (1) { delay(1); }
  if (bt.available()) {
    BluetoothData = bt.read();
    Serial.println(BluetoothData);
uint8_t getFingerprintID() {
  uint8_t p = finger.getImage();
  switch (p) {
    case FINGERPRINT_OK:
      Serial.println("Image taken");
    case FINGERPRINT_NOFINGER:
      Serial.println("No finger detected");
      return p;
    case FINGERPRINT_PACKETRECIEVEERR:
      Serial.println("Communication error");
      return p;
    case FINGERPRINT_IMAGEFAIL:
      Serial.println("Imaging error");
      return p;
    default:
      Serial.println("Unknown error");
      return p;
  // OK success!
  p = finger.image2Tz();
  switch (p) {
      Serial.println("Image converted");
    case FINGERPRINT_IMAGEMESS:
      Serial.println("Image too messy");
      return p;
      return p;
    case FINGERPRINT_FEATUREFAIL:
      Serial.println("Could not find fingerprint features");
      return p;
    case FINGERPRINT_INVALIDIMAGE:
      return p;
    default:
      return p;
  // OK converted!
  p = finger.fingerFastSearch();
  if (p == FINGERPRINT_OK) {
    Serial.println("Found a print match!");
  } else if (p == FINGERPRINT_PACKETRECIEVEERR) {
    return p;
  } else if (p == FINGERPRINT_NOTFOUND) {
    Serial.println("Did not find a match");
    return p;
    return p;
  // found a match!
  Serial.print("Found ID #"); Serial.print(finger.fingerID);
  Serial.print(" with confidence of "); Serial.println(finger.confidence);
  return finger.fingerID;
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
  if (p != FINGERPRINT_OK)  return -1;
  // found a match!
please help…
Two instances of software serial, not going to work well.
You need to use an Arduino with two or more hardware serial ports.
SoftwareSerial can afaik have multiple instances but only one can be active at a time. So if the fingerprint scanner is active, messages from the Bluetooth get lost.
A combination of SoftwareSerial and AltSoftwareSerial is another option, that may work better together.
An Arduino Mega (with four hardware Serial ports) would be a good option for this project.
