Using flag to do a particular action only once
Hi! I am currently facing some problems when trying to use a flag to do a particular action only once. I wanted to print the value to move forward and turn left and continue to move forward all the way but this coding that I have done, it returns me forward, turn left, forward, turn right, forward, turn right and so on... Can anyone help me with this? Thank You so much!
int set1_flag = 0;
int previousAngle = 270;
int angleDouble = 0;
  if (angleDouble >= 0 && angleDouble < 90)
    Serial.println("Forward");
    delay(2000);
    if ((angleDouble <= previousAngle - 270) && (set1_flag == 0))
      Serial.println("Turn Left");
      set1_flag = 1;
      Serial.println("Turn Right");
I don't actually understand what you want to happen.
The outcome that you describe
Forward
Turn Left
Forward
Turn Right
Forward
Turn Right
Forward
Turn Right
Forward
Turn Right
is what the program code is designed to produce
If you only want it to print "Forward" after the first left or right then you should test for the flag first - something like this
if (set1_flag == 0) {
  // do stuff
  set1_flag = 1;
...R
Robin2:
Thanks for the reply! I will try out the codes too. The outcome that I want is as follows:
Forward
Turn Left
Forward
Forward
Forward
Forward
Thank You for the reply! :slight_smile:
I have found out the way to solve this problem and would like to share it here. The codes are as follows:
int set1_flag = 0;
 if (angleDouble >= 0 && angleDouble < 90)  //testing range for 270 and 360 turn left only
   delay(2000);
   if(set1_flag == 0)
     if ((angleDouble <= previousAngle - 270))
       Serial.println("Left");
       Serial.print("Minus Angle: ");
       Serial.println(previousAngle - 270);
       set1_flag = 1;
       Serial.println("Right Side");
       set1_flag = 1;
