I need to support an odd ball baud rate for the old CCD bus that runs at 7812.5 (1mhz / 128). It uses standard 8N1 framing.
Obviously I can not pass that to Serial.begin() since it is expecting an unsigned integer. Trying to flub it by doubling the value and sending two bits for every bit will not work since that will mess up the framing.
Any ideas on how I can achieve this? The best idea I have so far is to rewrite SoftwareSerial to support floats for baud rates.
Thanks everyone! I did try modifying AltSoftSerial, but I was getting no where with that. It turns out my test data was for the wrong country of origin.(MPH versus KPH)
Simply putting in 7812 with the hardware serial does work and when I switched to use other test data, ta-da!
