When I read a float from SD card, it rounds the number up. I just want it to display the actual value.
52.525 read by float = 52.53
thanks, Rudy
void readFile() {
long lg;
float f1, f2;
char text[10];
char c1, c2, c3; // space for commas.
// open input file
ifstream sdin(fileName);
// check for open error
if (!sdin.is_open()) error("open");
// read until input fails
while (1) {
// Get text field.
sdin.get(text, sizeof(text), ',');
// Assume EOF if fail.
if (sdin.fail()) break;
// Get commas and numbers.
sdin >> c1 >> lg >> c2 >> f1 >> c3 >> f2;
// Skip CR/LF.
sdin.skipWhite();
if (sdin.fail()) error("bad input");
// error in line if not commas
if (c1 != ',' || c2 != ',' || c3 != ',') error("comma");
// print in six character wide columns
cout << text << setw(6) << lg << setw(6) << f1 << setw(6) << f2 << endl;
// Error in an input line if file is not at EOF.
if (!sdin.eof()) error("readFile");
Maybe a stupid question, how do you print it? Simply using print(aFloat) will give you two decimals. A float has NO notion of the number of decimals you try to store in it. If you just want 3 decimals all the time it's better and more precise to use a fixed point notation. just save it as an int with value 52525 and know it contains three decimals. But unfortunately the fixed point support is 0 in Arduino itself so you have to write the functions to be able to use fixed point.
Is there a reason why you don't want to use the standard Serial object to display the output? If that's acceptable, you can use:
Serial.print(f1, 3);
to get 3 decimal places.
Thanks septillion. I'll try it.
econjack:
I don't want to display the result. It will be applied to a variable and used by the program. It displays on the serial terminal for testing only. Looks like I'll have to use some math to get the exact number to be read.
Here's a copy of the entire test program. The (, 3) you suggested caused errors during compilation.
* Each line of the file has three values, a long and two floats.
#include <SdFat.h>
// SD chip select pin
const uint8_t chipSelect = SS;
// file system object
SdFat sd;
// create Serial stream
ArduinoOutStream cout(Serial);
char fileName[] = "chdata.csv";
// store error strings in flash to save RAM
#define error(s) sd.errorHalt_P(PSTR(s))
// read and print CSV test file
void readFile() {
long lg;
float f1, f2;
char text[10];
// open input file
while (1) {
// Get text field.
// Skip CR/LF.
sdin.skipWhite();
cout << text << setw(2) << lg << setw(6) << f1 << setw(6) << f2 << endl;
// write test file
/*void writeFile() {
// create or open and truncate output file
ofstream sdout(fileName);
// write file from string stored in flash
sdout << pstr(
"Line 1,1,2.3,4.5\n"
"Line 2,6,7.8,9.0\n"
"Line 3,9,8.7,6.5\n"
"Line 4,-4,-3.2,-1\n") << flush;
// check for any errors
if (!sdout) error("writeFile");
sdout.close();
//while (!Serial) {} // wait for Leonardo
cout << pstr("Type any character to start\n");
while (Serial.read() <= 0) {}
delay(400); // catch Due reset problem
// initialize the SD card at SPI_HALF_SPEED to avoid bus errors with
// breadboards. use SPI_FULL_SPEED for better performance
if (!sd.begin(chipSelect, SPI_HALF_SPEED)) sd.initErrorHalt();
// create test file
//writeFile();
//cout << endl;
// read and print test
readFile();
cout << "\nDone!" << endl;
void loop() {}
