Hi there,
would like to ask a few basic questions before i try out myself.
In order to get Position feedback from four ball valves which are servo driven , i would like to use four potentiometers to give me an analog read.These readings should be changed in to percentage,which should then sent to an hitachi lcd display.
The best i could do was find a code which uses two potentiometers,however without a percentage conversion
I will post the code next.
The question is if this code can be extended,so i can use two more pots
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7,8,9,10,11,12);
int potPin1 = A1;
int potPin2 = A2;
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.clear();
pinMode(potPin1, INPUT);
pinMode(potPin2, INPUT);
lcd.setCursor(0,0); // Sets the cursor to col 0 and row 0
lcd.print("SensorVal1: "); // Prints Sensor Val: to LCD
lcd.print(analogRead(potPin1)); // Prints value on Potpin1 to LCD
lcd.setCursor(0,1); // Sets the cursor to col 1 and row 0
lcd.print("SensorVal2: "); // Prints Sensor Val: to LCD
lcd.print(analogRead(potPin2)); // Prints value on Potpin1 to LCD
"get Position feedback from four ball valves which are servo driven "
What is driving the servos?
presently the four servos are being controlled by an arduino mega.
I would like to use two arduinos in the whole system,to avoid patching two different codes.
step4step:
Then have the other Arduino communicate the value over Serial or so - will be more accurate and saves modifying your servos.
Usually people prefer to use a single system to avoid patching two different codes.
Typical beginners reaction. You have much more problems with two processors than you will have learning to do things properly in software.
