I found it kind of hard to create a descriptive topic title with the length Im allowed, so please bear with me.
Im trying to flash a LiteOn DG-16D2S. To read the key from the drive, you need a USB -> RS232 or Serial -> RS232 adapter. You can use a level shifter, or a MAX(3)232 chip. Ive read about one guy who used an Arduino, and connected the Rx and Tx pins to the respective points on the drive, and it worked for him. I tried doing this (both with 3v3 and GND connected and disconnected) but Im told by the program Im using that the "Serial data is bad".
I uploaded a blank sketch to the arduino (blank setup and loop) and connected the Rx and Tx pins on the Arduino to the Rx and Tx pins on the board. Am I missing something? Do I need to do anything to give myself access to these pins that Im not already doing?
For reference, here is the MAX3232 diagram (which wouldnt work for me anyway because I dont have a serial port):
And heres the pinout for the drive:
EDIT It seems that if I unplug the drive and plug it back in, the program will extract the key over serial 3-4 (out of six) times before giving me an error. It keeps giving me the serial data invalid error until I unplug and re-plug in the drive (unplugging and re-plugging the arduino makes no difference). May be a drive issue. I will keep this updated!
