I have wasted a day on this, I have before used a function to calculate a result using the same integers and just reloading the information and generating an answer.
I am obviously doing something stupid. I have posted the Mk 999 version below, it has changed many times today..
This time I am trying to scan the commons of 5 BCD switches, by sequentially taking pins 7,8,9 13, and 14 low, and feeding the 4 binary contacts ( through diodes ) to the pins 3 ,4 , 5 and 6 and saving the number as msg [n] = address. for sending by Virtual Wire.
I tried it with linking a wire between 6 and 14 which gives me the predicted 7 on the first loop, and then 15 for the next loops.
When I print the pins it is right , but the address always want to give 15.
I could do it separately, but its bugging me because I have been having some success with functions and arrays lately.. Time to phone a friend ![]()
#include <VirtualWire.h> // Wireless transmitter/receiver library
#include <avr/sleep.h> // powerdown library
#include <avr/interrupt.h> // interrupts library
int SW0 = 3; // bits to read from BCD switches - LSB
int SW1= 4; // bits to read from BCD switches
int SW2 = 5; // bits to read from BCD switches
int SW3 = 6; // bits to read from BCD switches - MSB
int add0; // address bits read from switches
int add1;
int add2;
int add3;
int comUnit = 7; // outputs to common contacts of the BCD switches
int comTens = 8;
int comHund = 9;
int comThou = 13;
int comAddr = 14;
int comcount;
//int switchbanks = 5; // change here for number of switches in unit
int pin2 = 2; // Int0 interrupt pin, refresh button to ground
int address = 0; // bits put together afteer reading switches
char msg [5]; // extra char added for address
// FUNCTION FOR READING DATA FROM BCD SWITCHES
void checkdata () // read and put together bytes function
add3 = digitalRead(SW3); // shift it left 3 places
add3 = add3 << 3;
add2 = digitalRead(SW2);
// shift it left 2 places
add2 = add2 << 2;
add1 = digitalRead(SW1);
// shift it left 1 place
add1 = add1 << 1;
add0 = digitalRead(SW0);
// now OR it together
address = address|add3;
address = address|add2;
address = address|add1;
address = address|add0;
Serial.print("data for switchbank ");
Serial.println(address);
int n = comcount;
msg [n] = address;
// * Name: pin2Interrupt, "ISR" to run when interrupted in Sleep Mode
void pin2Interrupt()
/* This brings us back from sleep. */
// * Name: enterSleep
void enterSleep()
/* Setup pin2 as an interrupt and attach handler. */
attachInterrupt(0, pin2Interrupt, LOW);
delay(50); // need this?
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // setting up for sleep ...
sleep_enable(); // setting up for sleep ...
ADCSRA &= ~(1 << ADEN);
PRR = 0xFF;
sleep_mode(); // now goes to Sleep and waits for the interrupt
/* The program will continue from here after the interrupt. */
detachInterrupt(0); //disable interrupts while we get ready to read the keypad
PRR = 0x00;
/* First thing to do is disable sleep. */
digitalWrite(comUnit, HIGH);
digitalWrite(comTens, HIGH);
digitalWrite(comHund, HIGH);
digitalWrite(comThou, HIGH);
digitalWrite(comAddr, HIGH);
sleep_disable();
// set up the pins as Inputs, Outputs, etc.
pinMode (comUnit, OUTPUT );
pinMode ( comTens, OUTPUT) ;
pinMode ( comHund , OUTPUT) ;
pinMode ( comThou , OUTPUT) ;
pinMode ( comAddr , OUTPUT) ;
/* Setup the pin directions, write inputs High to turn on internal pullups */
pinMode(pin2, INPUT); // our sleep interrupt pin
digitalWrite(pin2, HIGH);
// puts all BCD inputs to input with pullups
pinMode(SW0, INPUT); // LSB of remote Address
digitalWrite(SW0, HIGH);
// byte add0 = 0; // read the value of SW0
pinMode(SW1, INPUT); // LSB+1
digitalWrite(SW1, HIGH);
// byte add1= 0;
pinMode(SW2, INPUT); // LSB+2
digitalWrite(SW2, HIGH);
// byte add2 = 0;
pinMode(SW3, INPUT); // MSB of address
digitalWrite(SW3, HIGH);
// byte add3 = 0;
// Initialise the IO and ISR for VirtualWire
vw_setup(4000); // Bits per sec - had to double from 2000 with 8MHz 3.3V Pro-Mini
} // end of void Setup()
// wakes up here
for (int comcount=0; comcount<=5; comcount++ ) {
switch (comcount)
case 0:
digitalWrite (comAddr, LOW);
checkdata ();
// msg [0] = address;
digitalWrite (comAddr, HIGH);
case 1:
digitalWrite (comThou, LOW);
checkdata ();
// msg [1] = address;
digitalWrite (comThou, HIGH);
case 2:
digitalWrite (comHund, LOW);
checkdata ();
// msg [2] = address;
digitalWrite (comHund, HIGH);
case 3:
digitalWrite (comTens, LOW);
checkdata ();
// msg [3] = address;
digitalWrite (comTens, HIGH);
case 4:
digitalWrite (comUnit, LOW);
checkdata ();
// msg [4] = address;
digitalWrite (comUnit, HIGH);
case 5:
Serial.println("Sleep");
enterSleep ();
//default:
} // end of switch function
} // end of comcount 1-4
vw_send((uint8_t *)msg, 5); // send the character out
//Serial.println(key); // for debugging only
vw_wait_tx(); // Wait until the whole message is gone
delay (50);
// end of void loop
