Recently I have notice a distinct difference with the usage of the...
__FILE__
MACRO between the ESP GCC compiler and the SAMD GCC compiler.
When I use the following code...
// Call to print to serial the File Name + Dat + Time
void printVersion(void) {
Serial.print(F("\n"
"Sketch: " __FILE__ "\n"
"Compiled: " __DATE__ " " __TIME__ "\n"
"GCC: " __VERSION__ "\n"
"Code Designed & Rewritten by: \n"));
To embed this data within my code, for the ESP version of GCC (V10.3.0),
__FILE__
Will return just the file name, ie;
fileName.ino
But, when ever I use the same code and compile for an SAMD M0 device (only tested with Seeed XIAO SAMD device thus far),
__FILE__
will return the full path, including the file name.
I am currently using IDE;
Version: 2.2.1
Date: 2023-08-31T14:35:44.802Z
CLI Version: 0.34.0
Currently installed: esp8266 by ESP8266 Community, V3.1.2
and
Xiao SAMD: Seeed SAMD Boards, V1.8.5.
All files and libraries are up to date.
Any ideas?
