Using Geany for development in Linux
I just switched from Windows 10 to Linux mint and trying to use Geany for arduino development
I followed Robins instructions from past threads on the subject.
I can verify and download using the command line interface using :
joe@joe-450-a114 ~ $ python pythonbuild.py dev/Arduino/sample/sample.ino
When trying to run from Geany I get the error
Invalid working directory ""/home/joe/dev/Arduino/sample/sample.ino""
That is a valid path and I have permission to both the folder and file.
When i remove the "%d/%f" from the cmd the terminal opens with the error:
/tmp/geany_run_script_1KVMJZ.sh: 7: /tmp/geany_run_script_1KVMJZ.sh: /home/joe/pythonbuild.py: Permission denied.
it looks like from Geany I can not get python to execute for some reason.
Any help is appreciated. I know this is kind of non-main stream topic.
What command have you entered in Set Build Commands in Geany?
...R
Hello Robin,
Under Exectute commands
Command: ~/bin/pythonbuild.py
Working directory: "%d/%f"
Working directory is /home/joe/dev/Arduino/sample
File is : sample.ino
error is ;Invalid working directory ""/home/joe/dev/Arduino/sample/sample.ino""
noweare:
Hello Robin,
I think you should do this
Command:      ~/bin/pythonbuild.py "%d/%f"
Working directory:
In other words leave the working directory box empty
...R
I made the change you suggested.
I still get "Permission denied"
I don't understand how it will build from the command line.
I can run from the command line until I figure it out.
Thanks for that script.
I have not gotten to it yet but do you have syntax highlighting and auto complete working in Geany?
What happens if you enter the command from Geany at a terminal
it should run my Python program although it will fail because it does not have a .ino file to work on. If it does not run my Python program then your command is wrong.
Another thought is to enter the command which python
On my PC it gives /usr/bin/python which leads me to think you should not have the tilde at the start of your command.
...R
The ~/bin is where the pythonbuild.py file is, which is home/joe/bin folder
When i run the command without tilde I get pythonbuild.py: not found
When I run the command with the tilde I get ; permission denied
"which python" returns /usr/bin/python which is a shortcut to python 2.7
I used "python ~/bin/pythonbuild.py" as the command and the script ran.
I got an out of range error since %d/%f was not used as the working directory, so that makes sense.
When I did give it the %d/%f I got this error:
Invalid working directory "/home/joe/dev/Arduino/4X20OLED/4X20OLED.ino"
But that is the correct path so I don't know what it isn't liking.
The "shebang" in the script with the correct path to python so it I should not have to add python to the command.
Thanks for your help.
noweare:
Sorry, I got myself confused. I was thinking of the location of the python interpreter
have you got this line
#!/usr/bin/env python
at the top of your pythonbuild.py file
(It may need to be a different location on your system)
And is the file pythonbuild.py set as executable and do you have execute permission?
Another possibility is to change the command to
...R
Yes, I have the shebang in the file.
I going to re-install the software to see if that helps
This is not making sense. I've spent hours fiddling around,
reading the manual and it should of worked.
Do you have syntax highlighting and autocomplete working ?
noweare:
If that is working then my Python program should run (albeit do nothing) when you enter
in a terminal.
You said you get "permission denied" so that seems to be the main problem because you said it does work when you enter
and I presume it will run my program when you enter
You have not said if you tried using Geany with the command
python ~/bin/pythonbuild.py "%d/%f"
Yes, but the syntax highlighting is not identical to the Arduino IDE. To be honest the colours are meaningless.
...R
Robin2:
in a terminal.
"bad interpreter" when run as above. I had to put python in front, like the shebang isn't recognized
Yes, when entered at the terminal
Yes, it does at both the command line and Geany, but will run errors out in Geany if I enter
the %d/%f
I get the invalid working directory error
I am told ver 3.2 and later has arduino filetypes. I was using ver 2.7
...R
[/quote]
Thanks for your help Robin. I need to walk away from this for a couple of days. When I figure it out
I will post what if anything was going on. If I can figure it out. May just take a fresh re-install.
The way you have responded to my comments (by typing inside the quote) means I cannot quote your responses easily.
Are you sure you have set pythonbuild.py as executable?
What shebang have you actually got in your file?
the %d/%f
Copy and post the exact error messages
Those sound like Python version numbers. Code highlighting is something in Geany. It is not part of the Python language. Especially as the code you want to highlight is C++, not Python.
...R
joe@joe-450-a114 ~ $ ls -l pythonbuild.py
-rwxrwxr-x 1 joe joe 7126 May 21 19:39 pythonbuild.py
joe@joe-450-a114 ~ $ pythonbuild.py
bash: /home/joe/bin/pythonbuild.py: /usr/bin: bad interpreter: Permission denied
//shebang
#!/usr/bin python
command / working directory
~/pythonbuild.py %d/%f
15:49:00: Invalid working directory "/home/joe/dev/Arduino/sample/sample.ino"
When I was talking about code highlighting I meant ino file in Geany, not python
I can run your script from Geany now.
The shebang looked like this #!/usr/bin python but my system liked it like #!/usr/bin/python (without space)
In Geany I was still getting "invalid working directory" with the %d/%f so I took your suggestion and moved in
in with the command. Then it all worked.
Thanks again for all your help Robin.
Glad you have it working.
All systems will require it with the / instead of the space.
I know. That's why I did not understand your reference to versions 3.2 and 2.7
...R
Robin2:
...R
I meant 1.27 & 1.32 , ugh
Thanks again.
