Using get method to get data from web server to arduino
Im trying to use the get method to get data (PC server time) from web with wifi shield. But i cant seem to get it.
Im trying to merge these two sekeltal codes together.
Web client
This sketch connects to a website (http://www.google.com)
using a WiFi shield.
This example is written for a network using WPA encryption. For
WEP or WPA, change the Wifi.begin() call accordingly.
Circuit:
  • WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include <SPI.h>
#include <WiFi.h>
#include <Time.h>
#include <TimeLib.h>
char ssid = “yourNetwork”; // your network SSID (name)
char pass = “secretPassword”; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server = “www.google.com”; // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiClient client;
time_t prevDisplay = 0;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println(“WiFi shield not present”);
// don’t continue:
while (true);
String fv = WiFi.firmwareVersion();
if (fv != “1.1.0”) {
Serial.println(“Please upgrade the firmware”);
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println(“Connected to wifi”);
printWifiStatus();
Serial.println("\nStarting connection to server…");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println(“connected to server”);
// Make a HTTP request:
client.println(“GET /search?q=arduino HTTP/1.1”);
client.println(“Host: www.google.com”);
client.println(“Connection: close”);
client.println();
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server’s disconnected, stop the client:
if (!client.connected()) {
Serial.println(“disconnecting from server.”);
client.stop();
// do nothing forevermore:
while (true);
//setTime(0,0,0,2,8,2016);
if( now() != prevDisplay){
prevDisplay = now();
clockDisplay();
void clockDisplay(){
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" “);
Serial.print(day());
Serial.print(” “);
Serial.print(month());
Serial.print(” ");
Serial.print(year());
void printDigits(int digits){
Serial.print(":");
if(digits < 10)
Serial.print(‘0’);
Serial.print(digits);
void printWifiStatus() {
// print the SSID of the network you’re attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield’s IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print(“signal strength (RSSI):”);
Serial.print(rssi);
Serial.println(" dBm");
not very clear which service you are calling, I can see you are tying to connect to google.com.
Format the code using code tag, so your code will look like
Some code
