here are error message
:\Users\nitin\AppData\Local\Temp\arduino\sketches\DE3C819AC8FDD4EB126A324FA8F62D6F\libraries\SoftwareSerial\SoftwareSerial.cpp.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
my codes are:-
#include <IRremote.h>
#include <SoftwareSerial.h>
#include <GSM.h>
#define SIM900A "" // Insert your SIM card PIN if applicable
int receiverPin = 2; // Pin connected to the IR receiver
IRrecv irrecv(receiverPin);
decode_results results;
int relayPin = 4; // Pin connected to the relay module
int buzzerPin = 5; // Pin connected to the buzzer module
int alcoholPin = 3; // Pin connected to the alcohol sensor
SoftwareSerial mySerial(7, 8); // RX, TX for software serial communication
GSM gsmAccess;
GSM_SMS sms;
char remotePhoneNumber1[] = "+917906593906"; // Replace with first recipient's number
char remotePhoneNumber2[] = "+919982470615"; // Replace with second recipient's number
unsigned long lastIRTime = 0; // To track the last IR signal received time
unsigned long irInterval = 900000; // 15 minutes in milliseconds
irrecv.enableIRIn(); // Start the IR receiver
pinMode(relayPin, OUTPUT);
pinMode(buzzerPin, OUTPUT);
pinMode(alcoholPin, INPUT);
mySerial.begin(9600);
// Start GSM connection
while (!gsmAccess.begin(SIM900A)) {
Serial.println("GSM initialization failed. Check your SIM card or GSM connection.");
Serial.println("GSM initialized");
void sendSMS(const char* phoneNumber, const char* message) {
sms.beginSMS(phoneNumber);
sms.print(message);
sms.endSMS();
int alcoholValue = digitalRead(alcoholPin);
unsigned long currentTime = millis();
if (alcoholValue == LOW) {
digitalWrite(relayPin, LOW); // Deactivate relay
digitalWrite(buzzerPin, HIGH); // Activate buzzer
sendSMS(remotePhoneNumber1, "Jai Hind Sir, The Dvr is drunk");
sendSMS(remotePhoneNumber2, "Jai Hind Sir, The Dvr is drunk");
if (irrecv.decode(&results)) {
lastIRTime = currentTime; // Update last IR signal received time
if (results.value == 0xFFFFFFFF) {
digitalWrite(relayPin, HIGH); // Activate relay
digitalWrite(buzzerPin, LOW); // Deactivate buzzer
digitalWrite(relayPin, LOW); // Deactivate relay if unexpected IR code
digitalWrite(buzzerPin, HIGH); // Activate buzzer if unexpected IR code
irrecv.resume(); // Receive the next value
delay(100);
// Check if 15 minutes have passed without IR signal
if (currentTime - lastIRTime >= irInterval) {
sendSMS(remotePhoneNumber1, "Jai Hind Sir, The Dvr is not using Seat belt");
sendSMS(remotePhoneNumber2, "Jai Hind Sir, The Dvr is not using Seat belt");
digitalWrite(relayPin, LOW); // Deactivate relay if no IR signal
digitalWrite(buzzerPin, HIGH); // Activate buzzer if no IR signal
// Virtual serial communication with GSM module
while (mySerial.available()) {
Serial.write(mySerial.read());
while (Serial.available()) {
mySerial.write(Serial.read());
delay(100); // Adjust delay if needed
