Using Hall Sensor(TLE-4905) with Arduino Mega
Here is the code, reply #4.
That code is using the ICP(input capture) pin. ICP5 is on D48.
The OP claims that he only has the external clock source pin(T5) on D47 available.
If that's the case, you can not determine the pulse characteristics, but only the count the number of pulses in a period of time.
You will be using the timer/counter as a counter. Here is some sample code written for Timer1 on a UNO.
unsigned long count_period = 2000;
unsigned int count_to_rpm = 60000UL / count_period; //convert counts to RPM
byte number_of_sensors = 1;
unsigned long final_counts;
unsigned long start_time = millis();
unsigned long measured_time;
unsigned long current_time = millis();
  TCCR1A = 0; //initialize Timer1
  TCCR1B = 0;
  TCNT1 = 0;
  pinMode( 5, INPUT_PULLUP); //external source pin for timer1
  //set external clock source pin D5 rising edge
  TCCR1B =  bit (CS10) | bit (CS11) | bit (CS12);
  //Test pulses to confirm circuit 50 pps =  3000
  //pinMode(11, OUTPUT);
  //tone(11, 50);//test pulse jumper pin 11 to pin 5
  if (current_time - start_time >= count_period)
    TCCR1B = 0; //stop counter
    final_counts = TCNT1; //frequency limited by unsigned int TCNT1 without rollover counts
    TCNT1 = 0;
    measured_time = current_time - start_time;
    start_time = current_time;;
    unsigned int rpm = (final_counts * count_to_rpm) / number_of_sensors;
    TCCR1B =  bit (CS10) | bit (CS11) | bit (CS12); //restart external clock source
    Serial.print(measured_time);
    Serial.print("\t\t");
    Serial.print(final_counts);
    Serial.println(rpm);
