Using HardwareSerial to print to serial failing
Hello
I am a newbie so be gentle.
Here is my sketch I am trying to write to the serial port with no success.
#include "HardwareSerial.h"
long previousMillis = 0;
long interval = 2000;
 pinMode(13, OUTPUT);
 digitalWrite(13, HIGH);
  if(currentMillis - previousMillis > interval) {
      String test = SendInstruction(Serial,"Test");
This is the code in the function
SendInstruction(HardwareSerial serial,String command)
  int i;
  int commandLength = command.length();
  for(i=0; i < commandLength ;i++)
    serial.print(command.charAt(i));
  serial.print("#");
Now when I monitor the serial port all I get every 2 seconds is
"Te"
When I use Serial.print then it is fine but I need to get it working with HardwareSerial
The String Class uses dynamic memory which can cause too fragmented memory to be workable.
Looking at the code this seems not the case
THis line cannot work as SendInstruction does not return anything. It however might corrupt its call.
Please try
  int i;
  serial.println(commandLength);
  serial.print("#");
to see what length is processed
Hello
The result is 4 for serial.println(commandLength) and it prints nothing else after that just 4 every 2 seconds
and I added
return "true";
to the bottom of the method and still no success.
Please try this slightly modified version
unsigned long previousMillis = 0;
unsigned long interval = 2000;
  if (currentMillis - previousMillis > interval) {
    SendInstruction(Serial, "Test");
void SendInstruction(Stream &serial, String command)  // <<<<<<<<<<<
  int i;
  for (i = 0; i < commandLength ; i++)
  serial.print("#");
no need to include HWSerial,
used the Stream baseclass (so you can also pass SWserial as param)
and most important used a reference &
Thank you that is what I was looking for works like a charm
Serial IS an instance of the HardwareSerial class, so this statement makes no sense.
