Using hc-sr04 sensors with less pins
Hi guys, I´m trying to build a robot with UNO, but I need more pins. I´m using the hc-sr04 sensors. The sensors have four pins:
  • The VCC pin
  • The GND
  • The ECHO pin
  • The TRIG pin
I thought that if I connected the Trig pin to the same pin, and firts I turned it HIGH and I read the signal of the ECHO pin of sensor one, and later I turned it LOW, and HIGH again and read the signal of ECHO pin of sensor two I could save one pin but when I did that last night the sensors gave me some errors reading distances (for example sometimes i says that the distance was 0 when there was nothing in front of the sensor)
What could be hapening? Is correct to do what I have done?
HI Antoniobeta, I don't really see what your trying to do!! Connect the Trig pin to the same pin? What same pin, you don't make it clear.
Here's the code I use with all 4 pin, U/S modules, does the job for me:
Where's your code, what pins are you using.... More info please.
Regards
Mel.
long scanner(long cm)
    const int pingPin=7, EchoPin=8; // Set these to whay your using...
    long duration;
    // The SRF005 is triggered by a HIGH pulse of 2 or more microseconds.
    // Give a short LOW pulse before to ensure a clean HIGH pulse:
    pinMode(pingPin, OUTPUT);
    pinMode(EchoPin, INPUT);
    digitalWrite(pingPin, LOW);
    delayMicroseconds(2);
    digitalWrite(pingPin, HIGH);
    duration = pulseIn(EchoPin, HIGH);
    delay(100);
    // convert the time into a distance
    // inches = microsecondsToInches(duration);
    cm = microsecondsToCentimeters(duration);
    return (cm);
long microsecondsToCentimeters(long microseconds)
    // The speed of sound is 340 m/s or 29 microseconds per centimeter.
    // The ping travels out and back, so to find the distance of the
    // object we take half of the distance travelled.
    return microseconds / 29 / 2;
Yes you can cut it down to one pin: http://letsmakerobots.com/node/36885
// Per.
Thank you zapro!! That´s what I was looking for.
Cactusface I was meaning to connect the two trig pins to the same pin of the arduino and read a sensor at a time.
