Using HiLetgo TFTLCD shield with Adafruit libraries
Hello.
I purchased 2.4" LCD shield off Amazon, made by HiLetgo (says ILI9341 compatible). Instructions say I gotta use Adafruit TFTLCD libraries. I believe that means they did not release their own libraries and claim compatibility with Adafruit shield. Correct?
Now I run the tests, everything seems ok (display and touch input)
But I need to use some of the Digital Pins for other functionality within the same project. It is my understanding that defining USE_ADAFRUIT_SHIELD_PINOUT in the Adafruit_TFTLCD.h file will enable certain communications protocol between the Arduino and the Shield via the 4 SD_ pins, therefore releaseing D0...D13 for other purposes.
However, when I am defining USE_ADAFRUIT_SHIELD_PINOUT suddenly the example program will no longer display anything on the screen.
Am I misusing / misunderstanding or there is only limited compatibility between Adafruit and HiLetgo and I should buy Adafruit genuine Shield?
Any other way of using this HiLetgo screen shield in such a fashion that my D0..D13 pins are left available?
Shall I get capacitive or resistive display?
Thanks
@bavareze
Your topic was Moved to it's current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
Please post a link to the actual screen that you have bought. e.g. Amazon Sale page.
good point
https://www.amazon.com/gp/product/B0722DPHN6
Install MCUFRIEND_kbv via the IDE Library Manager.
Plug the Shield into your Arduino as Nature intended.
Run all the library examples.
David.
