I would like to have some help with my Arduino project. I’m using Arduino ADK with HT12E encoder and HT12D decoder chips. I would like to make a remote control for 4 servos using a transmitter and receiver. I have a sketch that works with 4 LEDs and it works great just like I need, but when I try to make 1 servo move, the servo go from one set point to the other with no control in-between. I’m sure it has something to do with the servo but not sure what it would be. I’m new to Arduino and having a little problem understanding how it works but I’m enjoy myself trying.
A question like this requires a schematic and code uploaded. You are not going to get any help until you do that.
great, sorry i will have to get that for you.
Servo test code you can use to verify your servo is operating as desired.
// zoomkat 12-25-13 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// Send an a to attach servo or d to detach servo
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
String readString; //String captured from serial port
Servo myservo; // create servo object to control a servo
int n; //value to write to servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7, 500, 2500); //the pin for the servo control, and range if desired
Serial.println("servo all-in-one test code 12-25-13"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
// attach or detach servo if desired
if (readString == "d") {
myservo.detach(); //detach servo
Serial.println("servo detached");
goto bailout; //jump over writing to servo
if (readString == "a") {
myservo.attach(7); //reattach servo to pin 7
Serial.println("servo attached");
goto bailout;
n = readString.toInt(); //convert readString into a number
// auto select appropriate value
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
bailout: //reenter code loop
Serial.print("Last servo command position: ");
Serial.println(myservo.read());
readString=""; //empty for next input
I powered my servos with separate power supply and everything seems to worked as planed. Can anyone explain to me why I can't power my servos from the same power supply as my arduino.
Remember this ?
nieuport:
If the power supply is small, the servos will draw down the power supply voltage to the point the arduino resets.
That doesn't sound like a reset.
