Hi All,
Setting up the LCD module with the “LiquidCrystal_I2C” library using the line
" LiquidCrystal_I2C lcd( 0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE );" is it possible to use other ports for the
SDA and SCL lines? The reason being to tidy the pcb layout, where it would be better to use say A6 and
A7. At present I have it operating via an I2C interface module using power pins and just SDA and SCL
lines. Any info on using that library would be fine.
Cheers … Mike B
