using i2c library with timer0 interrupt (ESP8266)
I need to read some values from I2C , on strict time. SO I am using timer0 ISR.
  noInterrupts();
  timer0_isr_init();
  timer0_attachInterrupt(timer0_ISR);
  timer0_write(ESP.getCycleCount() + 80000000); //80Mhz -> 80*10^6 = 1 second
  interrupts();
void timer0_ISR (void){
  tog = !tog;
  digitalWrite(LED_BUILTIN, tog);
  // Set-up the next interrupt cycle
   timer0_write(ESP.getCycleCount() + (80000000)/1); //80Mhz -> 80*10^6 = 1 second
LED toggles very accurately. But when I use it with the I2C library. It doesn't give correct results.
   readI2CPort();// this communicates on i2c.
I2C depends on interrupts so it must not be called from interrupt context.
Thanks,
Let me figure out other ways.
