Using I2C on the Arduino Portenta H7 with Breakout Board
Tried to communicate with CY8C9540A via I2C.
I could find the device or at least the address of the registers with an I2C Scanner,
but other than that I was not able to communicate with the port expander.
I tried every available I2C bus on Arduino Portenta H7 with Portenta Breakoutboard:
Wire.begin() which should be the same as Breakout.I2C_0.begin()
Wire1.begin() which should be the same as Breakout.I2c_1.begin()
Wire2.begin() which should be the same as Breakout.I2C_2.begin()
I also tried the CY8C95XX library.
Then I also tested the same parameters with an ESP32 which I had laying around.
But I just couldn't run a simple OUTPUT Task on the Expand7Click.
I reviewed every connection several times, and even changed some cables,
but I could communicate with the port expander.
When running the I2C Scanner I couldn't find the EEPROM which was strange as well.
Then I decided to test MCP23017 which I couldn't get to run either on the Portenta h7 Pro with the breakout board.
So I tried running the same code using the Adafruit MCP23XXX library on an ESP32, an ESP8266 and an Arduino UNO which I had laying around.
My Sketch was the blink example which toggles on and of an LED at a given pin every 500ms.
This worked right out of the box for all 3 µC I tested. But the exact same code refused to run on the Portenta,
I tried again every possible combination and variation with the 3 I2C busses as well as an
additional library for the I2C which someone posted in the Arduino forum. It just didn't work. to make sure I didn't damage the MCP23017
I plugged it into the three other µC again which had the same code stored so I just had to power everything up and it just worked.
I also tried a different MCP23017 and again it works on the ESPs and the UNO but not on the Arduino Portenta H7 pro.
Strangely when running the I2C Scanner again, I couldn't find the MCP23017 at 0x20 on either of the three I2C busses,
but I could find the CY8C9540A using the exact same wiring. However, on the ESP32, ESP8266 and the Ardunio UNO I could find the MCP23017 at the I2C address 0x20.
I asked ChatGPT, added PULL_UP resistors to the I2C lanes changed the I2C frequencies and everything I could find out.
It is a bummer that the Pro Series of Arduino is so badly documented and not functioning how it is intended, even more considering the high price Tag.
I wanted to connect the Interrupt Pins of the port expanders to the breakout board, but I did not find any information about the GPIO Pins on the Breakoutboard that support interrupts.
Here is the I2C_Scanner which I used on the Portenta H7:
#include <Arduino.h>
#include <Arduino_PortentaBreakout.h>
#include <Wire.h>
  Wire.begin();
  //Wire.setClock(100000); //tried different I2C frequencies as well
  Wire1.begin();
  Wire2.begin();
    while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
   while (!Serial);
  Serial.println("Looping...");
  byte error, address;
  int nDevices;
  Serial.println("Scanning I2C_0");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error =  Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknown error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
    Serial.println("done\n");
  Serial.println("Scanning I2C_1");
  nDevices = 0;
    Wire1.beginTransmission(address);
    error =  Wire1.endTransmission();
    if (error == 0)
      if (address<16)
        Serial.print("0");
      nDevices++;
    else if (error==4)
      if (address<16)
        Serial.print("0");
  if (nDevices == 0)
  Serial.println("Scanning I2C_2");
  nDevices = 0;
    Wire2.beginTransmission(address);
    error =  Wire2.endTransmission();
    if (error == 0)
      if (address<16)
        Serial.print("0");
      nDevices++;
    else if (error==4)
      if (address<16)
        Serial.print("0");
  if (nDevices == 0)
  delay(5000);           // wait 5 seconds for next scan
Two other "problems" I discover are that
A) the 3,3V Pins only output 3,0V
B) Using the Arduino IDE 2.0 and 1.8 it takes like 5 min to upload a simple blink example to the Arduino Portenta, that is why I switched to Platform.io were it only takes about 20 sec.
