Is it possible to use the i2c pins, SDA (4) and SCL (5), as regular digital pins?
I want to make an additional serial port on my board. (duemilanove atmega168)
Yes, as digital pins or analogue pins. It is all in the setup.
So even though those pins are made for i2c i can use this code?
#include <SoftwareSerial.h>
SoftwareSerial mySerial(4, 5); // RX, TX
if (mySerial.available())
Serial.write(mySerial.read());
if (Serial.available())
mySerial.write(Serial.read());
Yes you can use that code.
No those pins are not the I2C pins, the I2C pins are the ANALOGUE pins 4 & 5
If you want to use the analogue / I2C pins as digital pins you use pin numbers 18 & 19
They are not made for I2C it is just that I2C is one of the modes they can operate in.
