So I'm doing a project where I need to combine several different sketches into one.
I have 12 different buttons that I want to set to the different sketches to switch "mode"
(i.e. button 1 = follow me mode, button 2 = remote mode, button 3 = still mode)
So I'm thinking of using an if statement to switch between them.
im not sure on exactly how to use it but like this-
if (button1 == HIGH) then val=1
if (clearbut == HIGH) then val=0
[^ something so the button is always active unless cleared]
if (val == 1) do void followme()
the follow me void here
if (val == 2) do void remotemode()
etc.
I would use functions but I cant put functions inside of functions for what I know
I can try to upload the codes but there's a lot of text on it
Harrypph:
You can not declare / define functions inside other functions. But you can put calls to functions inside other functions.
If you think about it, you call functions from within other functions all the time. loop() is a function, setup() is a function, pinMode(), digitalRead() and digitalWrite() are functions, etc. And you do call e.g. pinMode() from in setup() digitalRead() in loop().
if(digitalRead(button1)==LOW)
// call a function
blinkIt();
void blinkIt()
