I have a question regarding the following smoothing code which I downloaded from this site and works fine:
Question: How can I use this code:
int userInput=Serial.read();
if (userInput=='1' )
to get this functionality:
- User types "1"
- Loop runs 10 times, averaging out the values at A0
- Serial prints the average of the 10 measured values
- Stops until user types in "1" again.
Many Thanks for any help!
Kind regards,
Hanss
zurich
Smoothing
Reads repeatedly from an analog input, calculating a running average
and printing it to the computer. Keeps ten readings in an array and
continually averages them.
The circuit:
- Analog sensor (potentiometer will do) attached to analog input 0
Created 22 April 2007
By David A. Mellis dam@mellis.org
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
// Define the number of samples to keep track of. The higher the number,
// the more the readings will be smoothed, but the slower the output will
// respond to the input. Using a constant rather than a normal variable lets
// use this value to determine the size of the readings array.
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int inputPin = A0;
// initialize serial communication with computer:
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
// subtract the last reading:
total= total - readings[index];
// read from the sensor:
readings[index] = analogRead(inputPin);
// add the reading to the total:
total= total + readings[index];
// advance to the next position in the array:
index = index + 1;
// if we're at the end of the array...
if (index >= numReadings)
// ...wrap around to the beginning:
index = 0;
// calculate the average:
average = total / numReadings;
// send it to the computer as ASCII digits
Serial.println(average);
delay(1); // delay in between reads for stability
